1 - 3 of 3 Posts
Hi guys, I have just conducted a cooling system flush on my 07’. The manual says it should take 2.9Litres including the overflow but it seems to only want to take 2Litres.
I conducted the flush (vinegar & distilled water cleanse + distilled water flush) and bleed as the manual instructed including the draining through the water pump and the plug at the front of the cylinders.
Any ideas what I am missing?
I appreciate the help!
If you've refilled and bled the air out of the system and the the fluid level shows between Min and Max on the reservoir, then you're done and it doesn't matter how much actual fluid it took. You don't measure coolant to the tenth of a litre or US gallon. If you see "2.9L" in the manual, then make sure you buy 3.0L of it to refill and you fill it up until it's full. That's it.
1 - 3 of 3 Posts
