1 - 10 of 10 Posts
Retired post whore
Someone posted saying Windex was the cure all for this problem.
Newfie Bullet
I got the smoked theme goin on my 10....smoked front and rear signals and the tail light is smoked as well...Looks cool when you connect the lil yellow wire off the tail light to the signals...Looks like the whole left or right side of the tail is one big signal light..
put a bit of carb choke cleaner, or brake parts cleaner on a paper towel and test it out... it made my 636 tail light look brand new.... wd 40 works too i read....
so does glass cleaner (the aerosol kind)
OR you could tint them black and never worry about them again
Any cleaner wax should work. Or even plexus the stuff used to clean clear plastics works great for this stuff.
In a worst case situation i would try a mild rubbing compound that you use to buff out swirls in your paint.
1 - 10 of 10 Posts
