Well my bike used to start and run fine, now its getting so much fuel it wont start or blows flames when it does fire. The only thing that has changed since storing it in my heated garage is that I took it out and rode it twice in 30+ degree weather and now this.
I did put seafoam in the tank before it sat but Im lost as to where to look next....
Synced TB, no fuel leaks, pulled plugs cleaned them and it started right up... but the next day it flooded when i tried to start. No codes, NOTHING! unhooked pcIII to eliminate anything and still no diff.
Has anyone ever had injectors leak down??? I am going to check fuel pressure and do a leak test on the throttle assembly tomorrow, but I am so angry and lost...........................:dontknow:
Any help will be greatly appreciated.
