1 - 9 of 9 Posts
· Retired post whore
Update to Nissin calipers from a ZX6 or ZX14. There are numerous threads on this topic. Some members are also using cbr 1000 calipers.
so the problem is in the calipers? will these other brake calipers bolt up th the stock brake mounts
The Nissin calipers bolt up with no modifications. You should consider stainless lines too if you are going to do the swap.
1 - 9 of 9 Posts
