1 - 8 of 8 Posts
i looked at a parts fiche and the 06-07 wheels have a part# 41073-0081-r2 and the 05 wheels have a part# 41073-0050-r2 is there a difference??
Accountant in training.
I am not 100% sure...
But I think the rear wheels are inter-changeable, but the fronts are not. I think they use a different axel.
Maybe 9R to 10R can confirm or correct me. He has both the 1st and 2nd gen.
Chris
I know you can use the rear never used the front from an 06.
You can use the front off an 07 08 zx6r though ;-)
La Flama Blanca
The rear wheels on all zx10R's are the same the fronts are different. 04-05 have a smaller axle diameter than the 06-09. Not sure what the different years of 6R uses.
Speed Freak
I think its time we get a sticky on 04-05 to 06-07 wheels.......
the rear is the same the front is not, the 04-05 has a 24mm axle and the 06 has a 20mm axle so either swap internals and make it work on the front or get same year forks....
1 - 8 of 8 Posts
