05 brake swap
437 Views 4 Replies 5 Participants Last post by  trackaddict
I know this is a question that has been brought up many times but no recent updated post since around 2012. But, I was looking to see if there were any new bikes brakes that were swappable to an '05. I know the older zx14s and the zx6 work but, do any of the gsxr (I heard 16s) bolt straight up?
  • Like
Reactions: 1
1 - 5 of 5 Posts
the kawi line up makes it to easy... figure out what size rotor you want 300/310/320 and go for from there.. the 330mm from the 16+ is not a very good idea, as calipers do not fit with the oem wheel so easy.
  • Like
Reactions: 1
The ZX6R Nissins work great on my ‘05, direct bolt on. I also did lines, pads, Brembo MC and Braking rotors. Did the trick.
This was the route I went and it worked great.
Yep, Nissins. Off of ebay for a decent price. Lines and a new MC. Brakes are as good or better then my full Brembo setups on some of the Ducati's I've owned.
You need Nissins from the first Gen ZX14, Concours and I believe the 07+ 636. Direct bolt on calipers.
1 - 5 of 5 Posts
