Hi I'm hoping someone can help me, does an 06 sump pan and pickup fit an 05 engine? i have a 05 zx10 powered car project and the large sump is causing me headaches, thanks
Would it be more economical or practice to buy a replacement motor off of fleebay?
What is the cost of having someone rebuild the motor?
My bike is a daily rider, I'm paying for my own college, and I've never been to the track. Cost and reliability would be my main concerns.
I've looked at...
Recently bought new airshifter but didnt come with kill box. My last shifter was runing a ignition kill box but heard fuel kill is easier on the valves and to dial in. My question for the guys who run airshifters is which box you think is better?
Sent from my SCH-I545 using Tapatalk
If a gen 4 throttle body, wire harness and ECU are installed on a gen 5 engine, will a gen 4 gear position sensor work properly on the gen 5 engine? I've read that a gen 4 gearbox can be installed in a gen 5 engine and then the gen 4 gear position sensor will work. I'm wondering if the gen 4...
Hey guys i just bought a new 18 zx10r abs, absolutely love this bike. It has a quick shifter which i love, i want an auto blipper so i can shift down without the clutch as well. i read a bunch of other forums and postings about it but im still confused, no one has actually explained the entire...
Ok, finally got around to taking readings. This is for a 04/05 ZX10R but 06/07 models should work the same unless the GiPro is different for each models as they should have different pins(maybe different part # as well because of the pins) but most likely the same for both as the gear mechanisms...
