1 - 20 of 21 Posts
Ok yes, I've used the search button. No, I've not come across a thread like this. Yes, this is the right forum for my post.
Basically, I am looking to get one thread going on the dreaded generator issue. Maybe to have mod sticky this.
I have an early production 04'.
I am looking for some info:
Has your stator gone yet?
How many miles do you have on it or how many before it went?
Any tell tale signs to it going?
I have an 04' with 7700 in miles. My lights seem to be bright and don't fluctuate when the bike is revved. I have cam chaing noise. Thats about it.
Premium Member
Same situation you are, but mine is at 57,000 km. No problems yet. Knock on wood.
edit: serial number ends in 001498.
mine 39000 km...got all the marble sound, cam chain sound...but i place my hand on the generator cover...don't feel abnormal vibration...keep finger cross....
By the way wat's ur #VIN number ?
Wonder if there's any difference with the foreign models (outside USA)?
The last numbers of my VIN are 015289 (all numbers after the "A")
Mine has the CCT sound as well but lights seem to be bright and don't flicker.
Mine is 04 at 14000 in miles. Done at least 20 trackdays in fast group.
I inspected the generator a year ago and it was like new. No sign of abnormal wear. Replaced the side washers just in case. Side clearance were 0,6mm, which is minimum according in shop manual.
The engine has a lot of gear whine since day one, but i understand it is normal.
The VIN number is 14000 something.
Thanks for the info. Can you explain a little more about the washers?
Hard to explain without pictures... But i`ll try. There are thrustwashers in both sides of the rotating drum. The sideclearance is adjusted by using various thickness steelwashers behind the thrustwashers. I have heard that the thrustwashers may wear quickly and cause excessive sideplay to the rotating drum. Also i thought that if the sideclearance is kept in the minimum, there is better oilpressure in the actual rotating drums bearings. Thats why i replaced the thrustwashers just in case, despite all seems to be fine and within specs.
Sorry my bad english :sad:
Mine's a 04 ending in 0034XX with 17k miles. Did the manual CCT like bloo did recently, but haven't had any problems with the generator [knocks on desk]. Lights are strong, no weird noises, haven't checked it, but no need to yet.
Too bad no one knows when KAWA did the rectification. (starting from which #VIN no.). Mine is#018108, hopes is the updated version...:rolleyes:
I have an '04 that I swapped out with the '05 part last year, at around 50,000 miles. It had not yet failed.
I swapped as a preventative measure.
I think the consensus on this failure is that it's caused by rapid direction changes (leaning the bike side to side) while the engine is at high RPMs, as during track day use or competition.
As the generator turns at twice the engine RPM, high gyroscopic effects generate lateral forces pushing the poorly fixed rotor sideways, grinding engine cases and stator...
Most bikes won't see this failure on the street.
Wow...that makes my worry double...the pervious owner of my bike goes to track quite often....keeps both my finger cross now...keep hearing marble noise nowadays........
50,000 miles?
Mine will never fail then, I ride like a sissy.
Thats a tremendous amount of miles.
I've also heard that keeping a fresh battery in there helps as well.
I can't imagine that the minimal strain of a less than fresh battery causing the bearing failure. I would think that gyro effects, never up-shifting, etc would be more harmful for it than it having a little bit of resistance charging a battery. That's just my thoughts though.
I think it's insane that they designed the gen to whirl at 25k RPM. That's nutty.
Lenshead have you had to do bearings rings anything? That's awesome
When I installed the generator, I took the opportunity to adj valve clearance as well. Afterwards I did a compression check, found it low and pulled the head to freshen the valve seats. Replaced stem seals while I was at it.
That's about it barring regular maintenance.
That's awesome! I ride year round so this is great news to me. The seat refurb was the only cause of comp drop? Was it feeling weaker?
1 - 20 of 21 Posts
