1 - 2 of 2 Posts
I could use a little help. I am trying to take the front wheel off of my 04 for the first time. I have had several bikes in the past but for some reason on this one I cant get the 22mm nut off of the right hand side. I loosened the 10mm axle nuts and then tried cranking the crap out of the 22mm nut but with out any success. Do I need to loosen the allen side instead?
No, I had the same problem and had to use a breaker bar to break the seal that it has with the allen side nut.
1 - 2 of 2 Posts
