1 - 6 of 6 Posts
:dontknow:Could possibly be the voltage rectifier draining it off. Or you just got a grounded generator. :dontknow:
if all that checks out, check the wiring loom in general. i burnt mine out last year and it had this problem.
Also check the 3 fase connectors from the generator wiring to be properly seated. If one fase is loose you will have almost any charge and will drain power from the battery
The fase connectors are next to the throttle bodies.
1 - 6 of 6 Posts
