1 - 6 of 6 Posts
Part number 4-102
It is brand new I took it out to put on the bike and realized it wouldn't work with my gp shifting setup so its for sale or trade for 4-101 pull type
If your buying it i have the rod you need too 200$ for both parts
Check it out Ill put up a pic if needed but there is no damage it is new in box only taken out to prove I got the wrong one.
http://www.kneedraggers.com/details/Dynojet_Quick_Shifter_Kit_Kawasaki_ZX10R--610588.html
Discussion Starter · #4 ·
If you look at how your shifter works it will tell you if it will work for you.
If the rod is pulled towards the back of the bike when you up shift you would need a pull sensor.
Up shifting with stock sets in the stock setting requires a push sensor as the rod is pushed to the front of the bike to up shift.
Aftermarkets can go either way depending on the make and style so you just need to check whether it pushes or pulls the rod.
Check your sets out and let me know
1 - 6 of 6 Posts
