A friend is changing shift forks for a customer and only 1 came in. Customer is trying to make it to the track this weekend. Its popping out of second or not going in all the way. I told him he needs to change all 3 while your in there and the shafts too ( I do because its too much trouble not to). He's probably going to change the one for the 1-2 shift and the rest when they come i so he can make it to the track. Up to customer. But I thought I would ask any way. Which one controls the 1-2 drum ??
1 The single one on the shaft in the middle of motor. On top of shift drum looking from the bottom of the motor ?
2 The one on the shaft on bottom of the motor (2 on shaft). On the basket side. On bottom of shift drum looking from the bottom of the motor ?
or
3) The one on the shaft on bottom of the motor (2 on shaft). On the sprocket side. On bottom of shift drum looking from the bottom of the motor?
