Gen 1 green Reno - Kawasaki ZX-10R.net
post #1 of 6 Old 06-12-2014, 02:15 PM Thread Starter
rwarner56's Avatar
Gen 1 green Reno
I'll do a deal for forum members at $3000
http://reno.craigslist.org/mcy/4515823042.html
Sent from Motorcycle.com App
rwarner56 is offline
post #2 of 6 Old 06-12-2014, 04:21 PM
Omofo's Avatar
Dude, fork seals are $300 at most to have fixed. GLWS.
Ignorance is the enemy, let's set the record straight. If history must repeat itself, why worry while you wait?- Rodney Crowell
Omofo is offline
post #3 of 6 Old 06-12-2014, 05:06 PM Thread Starter
rwarner56's Avatar
I put $500 as a buffer.
post #4 of 6 Old 06-15-2014, 09:35 PM Thread Starter
rwarner56's Avatar
Sold. Thanks Bloo!
post #5 of 6 Old 06-15-2014, 11:27 PM
bluedevil's Avatar
Originally Posted by rwarner56 View Post
Sold. Thanks Bloo!
No problem....he just needs more information you said in one Thread you started you took the motor off the frame for quote
"This will be mostly whining about my first journey through a top end rebuild/valve clearance check."
It's in the shop now for fluid leaks I guess he knows I won't get to the problems fast so sent it to his mechanic......just asking if you have anything to add.
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
post #6 of 6 Old 06-16-2014, 10:26 AM Thread Starter
rwarner56's Avatar
Not really anything to add. I wasn't sure what all needed to be done but I knew that the valve cover was leaking in the normal spot and the valve clearance needed to be done. I replaced the gaskets on the valve cover, clutch, and stator cover. I told him that I didn't notice any leaks after I put everything back together and rode it. There are no oil spots in my garage where I park it. I torqued everything to spec when I put it back together. The only issue I knew of was the fork seal leak. I had heard that can chain noise is normal for gen 1's so I didn't worry about it. The can chain is probably the only thing that I didn't maintain properly. I feel bad about the leak but, I have no idea where/when it started because I've never noticed it before.
Gen 4: Anyone have pics of their green gen 4 with green LEDs? RightCoastRipper The ZX-10R 17 05-08-2012 08:48 PM
Reno Fernly fireman69 Track 12 03-24-2009 07:51 PM
June 21-22 Reno-Fernley ducatiryder89 Track 18 06-20-2008 12:58 PM
Reno-Fernley on 6/2 & 6/3 SuicideMachine Track 3 03-09-2007 01:54 AM
Reno-Fernley mad kaw Race and Stunt 5 06-19-2006 09:03 PM
