Gen 3: 2008-2010 Drag 08 ZX-10R - Kawasaki ZX-10R.net
post #1 of 15 Old 05-05-2016, 01:40 PM Thread Starter
Grease Monkey Bandit
AirborneMechanic's Avatar
Drag 08 ZX-10R
2008 Kawasaki ZX-10R
Complete frame off rebuild with new powder and custom paint on everything.
-EVIL 72-76 arm with new derlin, hugger, roller, chain guard
-ZVX3 Chain and 15/46 sprockets
-Carrozzeria VTrack wheels and tires, Michelin 60 series front less than 50 miles, new Shinko Hook-up rear, still has the knobbies and paint lines
-Forks internally lowered
-Busa shock
-Front fender lowering bracket
-Brock’s Sidewinder with 14” muffler and baffle
-DME pan
-09 Block with 4k miles, stock bottom end
-Decked head, Carpenter racing valve springs and titanium retainers
-2008 Kawasaki race intake cam
-2008 Kawasaki race exhaust cam
-Clutch- Welded clutch basket with larger/upgraded rivets, Gen1 clutch stack (with judder plate), Brocks slipper delete, HD springs and spacers
-Nitrous kit- Custom spray bar built with Nitrous Outlet components and stainless lines, currently jetted for 50 shot, MPS 2.5lb bottle, NOS mini controller setup on WOT activation, arm/disarm switch by gauges
-Tune- Utilizing Woolich Racing software there are two tunes in the ECU. One is a Q16 nitrous dyno tune and the other is a pump gas street tune. Again both wrote directly to ECU, you can switch with an ECU map switch or utilizing the Woolich Racing software. The nitrous tune dynoed at 229hp/122tq with a safe amount of timing pulled and stayed with a 50 shot. The bike has not been to the track on this nitrous tune yet but did run a 5.82 on pump foot shifting with me on it, I’m 230 suited.
-Shifter- Currently setup with the Woolich Quick Shifter ran by the ECU, you can adjust kill time, kill fuel, spark or both. The QS is setup is tied in with Boost by Smith’s shift system. You can auto shift, button shift or quick shift this bike.
-Motion Pro adjustable throttle system, has like 3 or 4 cams you can change out for different turn ratios
-New throttle and clutch cables
-Stainless brake lines
-Catalyst upper fairing
-CF front fender
-Brock's front strap
Probably more I'm forgetting.
Asking $10,495 obo
I can get more pics of specific parts if you want. Please pm me any questions or offers. Located in Nebraska, I can work out delivery or meet half way. Also listed on Psychobike and the ZX-10R sales page.
https://www.facebook.com/groups/6979...1247064266337/
ID:	371513   Click image for larger version
ID:	371529   Click image for larger version
ID:	371537   Click image for larger version
ID:	371545   Click image for larger version
ID:	371561   Click image for larger version
ID:	371569   Click image for larger version
"Homewrecker" Gen3 custom build by ZX-SIK-R in progress.... check the build thread: https://www.zx-10r.net/forum/f28/airb...ad-140226.html
AirborneMechanic is offline
post #2 of 15 Old 05-05-2016, 01:43 PM Thread Starter
Leak down and compression tests and new plugs within last 20 miles at RPMPowersports in Omaha, NE.
post #3 of 15 Old 05-05-2016, 01:45 PM Thread Starter
https://youtu.be/ifBDCrk8hHw
post #4 of 15 Old 05-05-2016, 01:47 PM Thread Starter
https://youtu.be/PZgcdTrpH2k
post #5 of 15 Old 05-05-2016, 01:56 PM Thread Starter
Few more pics...
ID:	371593   Click image for larger version
ID:	371601   Click image for larger version
ID:	371609   Click image for larger version
ID:	371617   Click image for larger version
ID:	371633   Click image for larger version
ID:	371641   Click image for larger version
post #6 of 15 Old 05-05-2016, 01:59 PM Thread Starter
Dropped the pan just to check her out after the tune was completed. Nice and clean.
post #7 of 15 Old 05-05-2016, 02:04 PM
SpazOnaZX's Avatar
Man.... why are you selling that bad mamajammer? That paint is eeeeeevil. :)
SpazOnaZX is offline
post #8 of 15 Old 05-05-2016, 02:15 PM Thread Starter
Also have catalyst drag seat new, never mounted that will go with. Forgot to list a few things like levers, rear sets, and tank cap.
post #9 of 15 Old 05-05-2016, 02:16 PM Thread Starter
Few more pics...
ID:	371673   Click image for larger version
ID:	371681   Click image for larger version
ID:	371689   Click image for larger version
ID:	371705   Click image for larger version
post #10 of 15 Old 05-05-2016, 02:21 PM Thread Starter
We will see what happens. I need a little start up money for some tools and equipment that I use for side jobs. I usually just work for someone else but I may as well just get the equipment and not have to share profits etc.
FS: Drag Seat for 06-07 ZX-10R Ruthless Racing Strip 6 08-30-2007 08:13 PM
Drag Seat for 06-07 ZX-10R Ruthless Racing Parts, Gear and Accessories 4 08-23-2007 06:10 PM
2006 10r drag racers. mainezx10 Race and Stunt 0 05-17-2006 02:21 PM
10r drag ninja6r Pictures and Videos 6 04-20-2006 09:53 PM
zx-10r drag racing video??? Stud_wit_style The ZX-10R 7 06-26-2005 02:32 PM
