Gen 1: 2004-2005 ZX10r Help needed - Kawasaki ZX-10R.net
 2Likes
post #1 of 16 Old 04-16-2019, 09:16 PM Thread Starter
ZX10r Help needed
So I bought a 2005 Zx10r today, and the guy who sold it to me left a lot, and I mean A LOT of things hidden, he was very shady. The gas tank has a leak in it and he put a gas tank cover over it so I didn't know that it was leaking. Also, it had some random tiny battery in there, and many other things. However, the main thing I need help with is I need someone who can replace a gas tank for me, I plan on ordering a used gas tank, but I have no idea how to do the replacement myself, and mechanics charge too much. Thanks in advance.
Mystsoldier is offline
post #2 of 16 Old 04-17-2019, 06:54 AM
Where are you located?
wheelz96 is online now
post #3 of 16 Old 04-18-2019, 02:57 AM Thread Starter
I am located in rancho cucamonga, california
post #4 of 16 Old 04-18-2019, 06:57 AM
Well swapping a gas tank is alot easier than you may think. If your buying a complete replacement tank than it's a matter of loosening 3 bolts or so. Usually you have 1 bolt in front of tank and 2 in rear on opposite sides. Once all bolts are removed you can gently pull up on tank to ensure it is completely loose. There will be quick disconnect lines and a couple breathers. Unplug and tank is free. Not sure on gen 1 if you have to remove any plastics on bike but if so do that first. Once tank is off you can do what you need to and replace a fuel pump if necessary.
Also, a small battery isn't necessarily a bad thing... The new LI technology allows batteries to get smaller and smaller. Does battery start bike? Yes? Don't worry.
Good luck and enjoy the new beast you just purchased!
post #5 of 16 Old 04-18-2019, 09:54 AM
zx racer's Avatar
To remove fuel tank on a gen1 youll need to remove passagner, driver seat, tank seat covers both side, one bolt rear and 2 bolts up front on the tank, unplug fuel hose and plug on shifter side and it will come off.
Sent from my SCH-I545 using Tapatalk
wheelz96 likes this.
05 ZX-10R SWB.
zx racer is offline
post #6 of 16 Old 04-18-2019, 10:01 AM
nakedinseattle's Avatar
you should go to the youtubes and start watching people wrench on the bike. it can be a great learning tool, just don't get distracted by the cat videos
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #7 of 16 Old 04-18-2019, 03:53 PM
NinjaLife's Avatar
Download the service manual for it, that'll help too.
If you get stuck on something, come ask us. Most of us won't bite lol.
NinjaLife is offline
post #8 of 16 Old 04-19-2019, 02:42 AM Thread Starter
Are any of you in rancho cucamonga and can come check out my bike and tell me everything you see wrong with it
post #9 of 16 Old 04-19-2019, 02:45 AM Thread Starter
Also do any of you have a spare gas tank? one that doesnt leak
post #10 of 16 Old 04-19-2019, 11:26 AM
Did you think to bring the tank too a place who repair gas tank the leak should be something who can be easily repairable check if the two side panel have the right screw. The guy maybe put two long screw and puncture the tank. When you put the tank of empty it and fill it up with water so you can see the damage or the leaks that way without doing a mess. Take a marker and identified the holes.
But you probably going to see the holes when you put out the tank.
ninja_12r2000 is offline
Gen 4: Help needed with 2014 ZX10R Amittrajit General Motorcycle Discussions 13 12-10-2014 02:08 PM
Gen 1: Help needed 2005 zx10r engine Petawawarace The ZX-10R 3 11-17-2014 09:12 PM
Gen 3: yam r6 to dream bike 08 zx10r, help needed for k-tech setup please, new here! taffgriff69 The ZX-10R 0 04-22-2011 05:23 PM
Help Help Help Help 99vorsi Performance and Tech 15 02-25-2007 04:34 PM
