Yamaha R1 monobloc calipers for ZX10r - Kawasaki ZX-10R.net
post #1 of 23 Old 01-26-2008, 12:50 PM Thread Starter
Send a message via Yahoo to realestateguy
I want to install a set of Yamaha R1 monobloc calipers on my ZX10r and want to know when Yamaha went to the current caliper on the R1. I was told the 2006 would bolt on with its standard 108mm mounting bolt pattern. So for you R1 experts, when did the current R1 caliper start being used on the R1's?
Bruce aka realestateguy
Let's talk about any real estate needs you have.
realestateguy is offline
post #2 of 23 Old 01-26-2008, 02:18 PM
2004 was the first year for the R1 radial calipers. R6 are also the same. They started in 2005.
zx10Rocket is offline
post #3 of 23 Old 01-26-2008, 02:20 PM
Rspec99's Avatar
Images: 11
The 2004 to 2006 R1's will fit although a spacer is required to fit it to the ZX10R rotors.
Those R1 monobloc brakes are very good. My R1 trackbike's brakes with performance friction pads and Goodridge superbike lines are incredibly good. After repeatedly hauling my bike down from 180mph at the end of the straights at Seattle Raceways, braking was always fade-free, and consistent.
Rspec99 is offline
post #4 of 23 Old 01-26-2008, 03:32 PM Thread Starter
Thanks for the information guys. I would like to know how long the required spacer is to adapt the R1 calipers to the ZX10r rotors. I am assuming you are talking about the OEM rotors. I'm running Brake Tech Axis 310mm iron rotors with a Brembo master cylinder and stainless steel superbike lines with their XRAC racing pads. Feel is great, however, Brake Tech says half their brake issues is with 4 piston 4 pad calipers and I want to try the Yamaha calipers believing they are 4 piston 2 pad units. Please advise.
If I don't go with the Yamaha calipers, I'm going to consider the Brembo cast monoblock calipers - very expensive option.
post #5 of 23 Old 01-26-2008, 03:40 PM
For what I've read The ZX-14 rotors bolt up with R1 calipers. I believe they are 310mm also. You should be good to go without the spacers with your rotor set-up.
post #6 of 23 Old 01-26-2008, 03:56 PM Thread Starter
Do you guys happen to know if the Yamaha R1 monobloc calipes are two pads or four per caliper?
post #7 of 23 Old 01-26-2008, 04:38 PM
Rspec99's Avatar
Images: 11
The R1 monobloc's are 4 piston 2 pads per caliper.
On my ZX-10R, my streetbike, I have the Brembo HP calipers and master cylinder along with Braking wave rotors, and absolutely love them. Not only is the braking power astounding, the feedback and control is just on a whole different level. If you were to compare them to say, a Ducati 1098's brakes, the HP's offer just as much stopping power, but with a lot more control. I found the 1098's forged monoblock Brembos to be very hard to modulate as they were extremely sensitive and powerful without offering the same level of feel.
The Brembo race billet monoblocks are even better for race applications with their Ti pistons, and more rigid one piece construction. I doubt for a street rider or even a seriously fast trackday rider would be able to reap significant benefits between the two.
Pic of the Brembos:
Rspec99 is offline
post #8 of 23 Old 01-26-2008, 05:36 PM
grunty-motor's Avatar
you either have to fit bigger discs or mashine down the calipers. no spacers needed. there are a couple of threads on how to make this work.
Mmmm - let me have a think about that....
grunty-motor is offline
post #9 of 23 Old 01-27-2008, 02:53 AM Thread Starter
Pic of the Brembos:
Are the HP's a one or two piece caliper? I understand makes a cast and forged one piece, with the forged unit having the Ti pistons. I'm not sure and would like to read about the current line of Brembo calipers, but the web site I went to only describes the new M4 calipers.
Very nice bike.
post #10 of 23 Old 01-27-2008, 02:54 AM Thread Starter
How big are the R1 rotors? I'm using Brake Tech Axis 310mm rotors.
05-06 GSXR 1000 brake calipers on 07 ZX10R Wind Draft Performance and Tech 27 04-02-2009 07:50 AM
ZX14 Calipers to ZX10r 07 Bladeboy Performance and Tech 42 08-09-2008 08:32 AM
Price for BREMBO M4 108 MONOBLOC Calipers ILOAD2 Vendors deals 1 12-22-2007 03:49 PM
Yamaha R1, Kawasaki ZX10R & Suzuki GSXR video.. madnessracing Pictures and Videos 5 02-23-2007 10:18 AM
FS '04 ZX10R rotors / calipers / front rim TAI10 Parts, Gear and Accessories 7 05-26-2005 07:51 AM
