What did you do to your bike today? - Page 603 - Kawasaki ZX-10R.net
 582Likes
post #6021 of 6028 Old 04-12-2019, 12:11 PM
Originally Posted by TheRoadWarrior View Post
watched some vids on this but never tried it myself yet... so you do the syringe push first... at each location or just 1? and then do a regular bleed after that?
seems everyone has their own method
Yes so if you decide to use syringe empty out reservoir with a rag or whatever but dont get fluid all over any painted bits. Start from furthest caliper and put 10mm wrench on, apply clear tubing on nipple which will be connected to syringe. Have about 20 inches of length. I believe 120ml syringe or bigger is what you will want. Pull piston out of syringe and slowly fill with fluid allowing it to fill up tube and syringe. Once filled add piston back to syringe and crack open nipple and very slowly push fluid through. Do not force it as the pressure can blow off the tubing from nipple. If your syringe is large enough you will push fluid up to reservoir. You can always top off syringe. This will push all air towards top and then you can try to bleed again if needed but air bubbles will be in top of system where they naturally want to go.
Hope this helps and you only need to do it from one location. This is what has worked for me in past but most times my vacuum bleeders does the job!
First thing I would do is try your new vacuum bleeder and see if you are getting any air bubbles.. If so try syringe method.
Keep using the zip tie method once your done.
TheRoadWarrior likes this.
wheelz96 is offline
post #6022 of 6028 Old 04-12-2019, 08:29 PM
TheRoadWarrior's Avatar
thanks, i might try all of the above.... i really miss having a firm grippy brake lever ;)
TheRoadWarrior is offline
post #6023 of 6028 Old 05-11-2019, 10:17 AM
weekend ride with friends
badexample and belkins like this.
post #6024 of 6028 Old 05-12-2019, 03:30 AM
if thailand had banjos, i woulda heard them playing.... some backwoods country road middle of nowhere and the pavement ends.... fuck it, keep going ;)
ended up in the rain on the way home, boots filled with water, that really sucked
belkins likes this.
post #6025 of 6028 Old 05-18-2019, 03:45 PM
Juh@'s Avatar
Preparations done for next sundays race, only oil change (looked like new) and a quick check.
ID:	422401   Click image for larger version
ID:	422403   Click image for larger version
badexample, belkins and Laczi like this.
post #6026 of 6028 Old 05-19-2019, 03:28 PM
ride with the squad down to a yamaha race event... tried out my first yammy, i think ill stick to my zx10r ;)
belkins likes this.
post #6027 of 6028 Old 05-19-2019, 04:42 PM
Palehorse's Avatar
Chain maintenance and a bath.
belkins and TheRoadWarrior like this.
08 250r-sold
..05 zx6r 636- sold
99 yzf R1-traded
04 zx10r-sold
06 zx10r - Sold
19 KRT zx10r - Current
Instagram.com/10r_Rome
Palehorse is offline
post #6028 of 6028 Old 06-14-2019, 02:46 AM
homeless dog security guarding my bike at 7-11
Went down today, but not on the bike. notilloc The Out House 11 05-18-2010 06:21 AM
Bike went down today 408ZX10R The ZX-10R 38 09-29-2006 11:15 PM
Got New Bike Today !! oneradten Pictures and Videos 15 08-13-2006 12:52 PM
Got a new bike today projekZERO The Out House 8 09-29-2005 08:06 PM
new bike today performancezx10r The ZX-10R 14 03-24-2005 06:50 AM
