Which way steels face for clutch swap - Kawasaki ZX-10R.net
 2Likes
post #1 of 25 Old 08-12-2019, 10:36 PM Thread Starter
Nfamous60's Avatar
Wanted to gain some input from the veterans on here about replacing the clutch. I went woth Barnetts carbon fiber friction plates and OEM steels as per kawi recommendations. After roughly 300 miles and some highways pulls i have clutch slip again. Checked cable adjustments and everything all good. Pulled the pack look at pix below. Only difference between new pack and old pack are the steels. New pack smooth side facing forward old pack sharp edge facing forward.
ID:	423757   Click image for larger version
ID:	423759   Click image for larger version
Nfamous60 is offline
post #2 of 25 Old 08-12-2019, 11:55 PM
I don't think it makes a difference the sharp edge vs the round edge facing in or out. Make sure to presoak the fiber plates in oil for a while before install. Make sure you have the proper stack height (should be somewhere in the manual). Make sure your oil does not have the energy conserving symbol on the container as certain oils will cause clutch slip. Hope this helps.
Boxtradamus likes this.
The Prophet is offline
post #3 of 25 Old 08-13-2019, 01:04 AM
when you open the clutch, did you see fiber residues? if there's a lot... may have already worn down for some reason.
Check the loose travel of 2 to 3mm of the clutch lever, because when the engine is hot the cable tends to tighten and without those 2 or 3 millimeters could cause the clutch plates to slip.
Guarf is offline
post #4 of 25 Old 08-13-2019, 06:57 AM
C3L1CA's Avatar
I've never paid attention to the steels like that, usually just throw them in. I do let my fibers soak in oil for at least an hour before putting them in.
I'd check clutch lever free play like mentioned above and maybe get some heavy duty springs to keep a little more tension on the clutch.
C3L1CA is offline
post #5 of 25 Old 08-13-2019, 10:54 AM
nakedinseattle's Avatar
did you replace the springs as well? that may also be the issue.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #6 of 25 Old 08-13-2019, 12:33 PM
Twistedsocal13's Avatar
Are you sure it's clutch slip? are you getting it in every gear or just 1 or 2 gears? Just checking cause I mistaked worn dogs for clutch slip way back. Also, wanna say sharp edge out but can't remember, same way they came out matters from what I have heard. Last, get the OEM cork fiber plates, they work, have heard negative stuff about almost every other aftermarket fiber plate out there. maybe it changed but why risk it when the OEM plates work so well.
Twistedsocal13 is offline
post #7 of 25 Old 08-13-2019, 01:17 PM Thread Starter
Nfamous60's Avatar
Far as measuring honestly i compared it side by side with the old pack very minor difference. The oil is 10w40 amsoil metric
post #8 of 25 Old 08-13-2019, 01:25 PM Thread Starter
Nfamous60's Avatar
when I got home after my third day riding noticed at the clutch cover the top was super tight at that point had the clutch slip and pulled it.. The slip isn't until higher RPMs though
post #9 of 25 Old 08-13-2019, 01:27 PM Thread Starter
Nfamous60's Avatar
i have 3 brocks springs and 3 of the springs supplied with the friction plates barnett has them listed as stronger then stock
post #10 of 25 Old 08-13-2019, 01:35 PM Thread Starter
Nfamous60's Avatar
Was doing some highway pulls hit from 1st at 40mph shifted to second third and 4th slipped and stayed at redline. Rode home which was bout 45miles away soft pulls on throttle no slip no slip at highway speeds took 5th slowly to 135mph no slip twist the throttle slips
