Gen 4: 2011-2015 halogen temps - Kawasaki ZX-10R.net
post #1 of 13 Old 05-23-2019, 09:49 AM Thread Starter
drewbiedu's Avatar
halogen temps
Bought some LEDs for my 2014 to replace the headlights, but decided I don't want to cut into my covers to fit the LED fans. Looking to just get brighter halogens - anyone know what temp (heat-wise, not color) the stock bulbs are running or what temps the housing can handle?
drewbiedu is offline
post #2 of 13 Old 05-23-2019, 05:58 PM
97grnrs's Avatar
You can use leds without cutting anything. I have the whole bulb fan and ballast in mine using Oem cover
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #3 of 13 Old 05-26-2019, 11:53 PM Thread Starter
drewbiedu's Avatar
What leds are you running? The set I ordered has a massive fan
post #4 of 13 Old 05-27-2019, 06:28 PM
97grnrs's Avatar
Mostplus brand. Same one that makes the opt 7
97grnrs is offline
post #5 of 13 Old 05-28-2019, 08:51 PM Thread Starter
drewbiedu's Avatar
Those fit in your gen4? I bought a set of NS Series by Stark and they look to be about the same size. About how much clearance do your leds have between the covers?
post #6 of 13 Old 05-29-2019, 06:32 PM
97grnrs's Avatar
Not much clearance at all but they fit ballast and all if carefully installed
97grnrs is offline
post #7 of 13 Old 05-30-2019, 12:10 PM
Do you happen to have a link to the bulbs you bought, and a photo of your install that you can post? I want to get brighter bulbs for my headlights as well, but like the OP I don't want to have to cut anything.
SJGetsome is offline
post #8 of 13 Old 05-30-2019, 05:11 PM
97grnrs's Avatar
I use these and the red base ones. Both fit without cutting if your mildly skilled on install
97grnrs is offline
post #9 of 13 Old 05-30-2019, 05:40 PM
Thanks. I'll check them out.
post #10 of 13 Old 05-31-2019, 10:33 AM
I bought a pair of LED's for my 2008 ZX10R. They plugged right in and work great. I purchased them here: https://www.ledperf.co.uk/leds-and-x...-987_1564.html
tisleeper is offline
Tags
2014 zx10r, bulbs, headlight, temperature
Average temps moving and in traffic? GreenGoblin Performance and Tech 23 09-09-2006 05:39 PM
Temps Tread70 The Out House 23 04-12-2006 02:14 PM
running temps fast_orange The ZX-10R 14 04-29-2005 09:05 PM
Coolant Temps? Aaron[MA] The ZX-10R 18 10-06-2004 04:55 PM
running temps blast_off Performance and Tech 15 08-28-2004 08:15 PM
