Gen 1: 2004-2005 Best Clutch Setup? - Kawasaki ZX-10R.net
 2Likes
post #1 of 14 Old 04-06-2015, 11:13 AM Thread Starter
Pussykat559's Avatar
Unhappy Best Clutch Setup?
Hey guys....I need some help. I have a 1st generation ZX10r. I have had many many clutch problems. From slippage to busting the clutch release comp puller. (I have busted three of these since November) I have a Brocks Clutch Cushion installed with EBC clutch fibers. I installed the cushion to avoid the clutch getting dry and ruining the fibers, but I cannot a clutch setup that works properly and allows me to race her on a regular basis.
I'm contemplating going to OEM clutch fibers with Barnett springs with Motul full synthetic oil. What are you guys using and what is the purpose of your riding. I would like my bike to be race-able but I also use it daily.
Frustrated and confused....please help!
Pussykat559 is offline
post #2 of 14 Old 04-06-2015, 11:40 AM
TechX's Avatar
What kind of racing you talking about drag or road racing. My Gen 1 is track only with ebc plates works great no failure issues. What engine mods have you done.
TechX is offline
post #3 of 14 Old 04-06-2015, 11:49 AM Thread Starter
Drag...No engine mods. I have a Power Commander V and an auto tune installed on her. I can get a few good launches on her and then shes done
post #4 of 14 Old 04-06-2015, 11:53 AM Thread Starter
I have been using harder springs to keep the clutch from slipping. But keep busting this piece open.
post #5 of 14 Old 04-06-2015, 12:59 PM
zx racer's Avatar
Im runin a dragpak with hd duty springs works great both street, strip.
Pussykat559 likes this.
05 ZX-10R SWB.
zx racer is offline
post #6 of 14 Old 04-06-2015, 01:46 PM
TechX's Avatar
Have you checked the clutch basket for play are the rivet's holding the basket securely in place. If your clutch basket is sloppy it could account for the problems your having. These small clutch's on the 10R's really do not like to be drag raced not enough clutch area to deal with all the heat of hard launching. From the looks of your clutch pusher you are having some severe internal clutch pressure's as the pusher is being destroyed from engaging and disengaging the clutch. Look for any marks on the clutch hub are their metal shaving's in the clutch basket. Do you have a Kawi service book for the bike. I would pull the clutch basket out and check all component's for wear and make sure all parts are in spec.
TechX is offline
post #7 of 14 Old 04-06-2015, 02:23 PM Thread Starter
I do have the service manual for the bike...I will inspect the hub today and make sure everything is secure. Thanks for your help!
post #8 of 14 Old 04-06-2015, 09:35 PM
TechX's Avatar
I know that these are simple things but make sure your stack height is correct and no warped steel drive plates.
TechX is offline
post #9 of 14 Old 04-07-2015, 06:09 AM
PatrickG's Avatar
Images: 15
We (me and wife) run a gen3 and gen4 with all OEM steels and fibers. NO Brocks Cushion kit and use my slipper clutch eliminator. The gen3 uses 4 KG HD springs with 1mm spacers under the hat and 2 Brocks heavy duty springs with his spacers.
The gen4 uses all OEM steels and fibers, 2 Brocks Extra HD springs, 2 GSXR1000 valve springs, 2 Brocks hd springs with spacers and 1mm washer.
We race every weekend from March until October and usually run 10-15 passes in 4-5 hours.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #10 of 14 Old 04-07-2015, 12:24 PM Thread Starter
Which oil do you run? A friend of mine recommended Motul 300V. Any recommendations?
Tags
clutch, release puller
Gen 4: clutch setup up? jramos Strip 4 02-05-2014 04:08 AM
Wanted: Slipper clutch setup pacobeagle Wanted: Buy or Trade 0 07-11-2012 02:14 PM
clutch setup on spray?? OK-10Romeo Strip 16 12-06-2011 11:24 AM
Gen 3: Clutch Setup Input Needed! BGoodwin22 Performance and Tech 3 07-07-2011 04:44 PM
drag racing clutch setup rated zx Performance and Tech 26 10-27-2005 08:42 AM
