The Evils of Syntetic Oil!! - Kawasaki ZX-10R.net
post #1 of 9 Old 11-02-2008, 11:50 PM Thread Starter
lenshead's Avatar
(An oldie but a goodie )
Beware of synthetic oil; it can do terrible things to you and your beloved motorcycle. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system.
It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action. Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the ground! But that's not all...
Synthetic oil will round off your gears and spin your bearings. It will Also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again.
Synthetic oil coats Your sight window and your timing window with a whitish pro-emulsification additive that is both non-removable and highly corrosive. Synthetic oil will completely leak onto the ground overnight and your dog will drink it and die. Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut.
It will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate your timing belts causing them to jump teeth and break your valves to bits. Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every six miles. Then it melts the black soles of your riding boots night before you walk across your new carpeting.
While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your swingarm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 55,555. It also dries out your wetclutch and wets your dryclutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure.
Synthetic oil hides your 10mm socket and puts superglue on your earplugs. Synthetic oil will scratch your faceshield and make your gloves shrink two sizes night before trackday. Synthetic oil stole your neutral and sold it to the Chinese for $1.25.
Synthetic oil will make you grow a tail. Synthetic oil will write long crazy e-mails to your Internet friends and then sign your name at the bottom.
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
post #2 of 9 Old 11-03-2008, 12:08 AM
BANNED
ZX10Rracer's Avatar
good to know!
ZX10Rracer is offline
post #3 of 9 Old 11-03-2008, 12:14 AM
ZX-10R_Sinner's Avatar
So THAT'S where all the 10mm sockets/wrenches have gone! I'm tired of buying those.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #4 of 9 Old 11-03-2008, 04:54 AM
or10r's Avatar
Originally Posted by zx10rracer View Post
good to know!
or10r is offline
post #5 of 9 Old 11-03-2008, 05:12 AM
Sebastian1000's Avatar
What the?
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #6 of 9 Old 11-03-2008, 07:15 AM
Paint N Flames's Avatar
So what about motul synthetic blend?
PAINT ~N~ FLAMES
CUSTOMS
Paint N Flames is offline
post #7 of 9 Old 11-04-2008, 05:51 PM
Post Whore
Nick.INF is offline
post #8 of 9 Old 11-04-2008, 05:59 PM
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
synthetic oil killed ma dog and raped ma wife
spikespiegel is offline
post #9 of 9 Old 11-04-2008, 06:08 PM
Custom Powder Coater
06blackpearl's Avatar
Images: 70
www.sportbikepc.com
Sport Bike Powder Coating,LLC
06blackpearl is offline
