zx10 air sh*ter problems - Kawasaki ZX-10R.net
post #1 of 12 Old 06-05-2008, 11:33 AM Thread Starter
my air shifter is missing 5th and 6th gears.Is the clutch be slipping a little? Does anyone have a air sh*ter (9oz CO2 bottle) on their 10 that had problems and if so could you tell me how to correct it - kill time, through on shift cylinder, more weight on lock-up, pressure to shift cylinder. Any help would be appreciated. Somtimes it will miss other gears, but last time out just 5th. Help it driving us nuts, we have the same shifter set up on all kinds of other bikes and it works great, just not on the 10s.
Thanks,
Mike
kawas1400 is offline
post #2 of 12 Old 06-05-2008, 03:42 PM
xspower's Avatar
i hade the same problem with mine the first time out this year i just put more kill into it and upped air pressure and shiftsfine now
2007 zx10 65", lowered ,drag pipe, best 60' 1.40, best 1/8 [email protected] [email protected]
2008 OXFORD DRAGWAY BIKE POINTS CHAMPION
[url]http://www.youtube.com/watch?v=cBqNG2xhyq8[/url
05 zx10r swb , (parted out !! )
02 drag busa next project!!
xspower is offline
post #3 of 12 Old 06-05-2008, 04:06 PM Thread Starter
Do you know what kind of pressure your sitting at? Any by chance the amount of kill time? I appreciate the reply.
post #4 of 12 Old 06-05-2008, 04:12 PM
ooohhh! i would like to no too! right now i'm running mps shifter with the high pressure co2 bottle. mps told me to run it at 130psi so i'm going to start there and then play with the kill time!
tbass is offline
post #5 of 12 Old 06-05-2008, 05:50 PM Thread Starter
Well let me know what you come up with for sure, Im running the same set up and havent had any luck. MPS Co2 with the muzzy bracket
post #6 of 12 Old 06-05-2008, 07:13 PM
xspower's Avatar
i run 150lbs and im not sure of kill time
xspower is offline
post #7 of 12 Old 06-10-2008, 02:16 PM
hotfocuson18s's Avatar
Send a message via AIM to hotfocuson18s
I have the Pingel electric shifter and i've noticed the same thing. in high RPM's it wont go into gear right. I have to back out of the gas a little to allow it to shift. Is there a recommended kill time to get the best performance out of auto shifter rather they are air or electric???
Women... Smarter than you think... BUT... not as smart as they think THEY are!!!! "Danny Glover, Death at a Funeral" (a must see film)
hotfocuson18s is offline
post #8 of 12 Old 06-11-2008, 11:37 AM Thread Starter
I have talked to several people and more than one said its probably clutch plates slipping, so I have re-installed my weights on my lock-up and Im heading to the track tonight to test I also moved my kill time from 70 mil to 90 mil / sec. with 160-170 psi in the shifter. I will let you know how it goes.
post #9 of 12 Old 06-12-2008, 10:51 AM Thread Starter
Alright I think I got it, 1st pass I tried 145 psi and missed 5th 2nd pass tried 165 psi and didnt miss a shift for the rest of the night even on nos - so its -- Muzzy lock-up with alum. bolts, 90 mil/sec's with 165psi. Our other zx-10 is having the same problem with the same set-up (except no lock-up), we checked the clutches and had a bad stack ht. so install new clutches. We will try that 10 this weekend, but Im almost positive that the reason for miss shifts were mostly because the clutch was slipping in the top of the high gears (5th and 6th).
Brian and Mike
Performancecycle2.net
post #10 of 12 Old 06-24-2008, 01:59 PM
Send a message via Yahoo to zxr92
What gears are you guys running to get into 6th gear at the end of the track? I'm one down on front and 5 up in the rear. But then I'm at 4,200ft elevation too.
zxr92 is offline
PC III problems 06zx14r ZX-14 Discussion 5 04-24-2008 05:19 AM
zx10 06 front brake problems gonzo Performance and Tech 14 04-14-2008 06:56 PM
buying a used 2005 zx10, any Known problems I should look for when I pick it up? adam833 The ZX-10R 23 03-13-2008 10:49 AM
problems with my DFI?? bigcov Performance and Tech 4 02-20-2006 04:15 PM
