wheel base length?????? - Kawasaki ZX-10R.net
post #1 of 9 Old 01-02-2011, 07:04 PM Thread Starter
i got a 04 zx10r and im extending it and not for sure how long i should go....my bike is currently set up as is....straped in the front and lowered 1.25" ,lowered 3" in rear,i will b trin -2+3(15,42) sprocket set up and im not exactly sure about how far to extend it I AM THINKIN 64"-64.5" the bike is stock motor and NO power commander........will this b a good length for this set up i am 170lbs not suited
any advise will b aprieciated thank you
jake_04_10r is offline
post #2 of 9 Old 01-02-2011, 07:37 PM
Supercharged Mod
As a first guess for mine, I crunched the numbers regarding approximate C of G position and the expected acceleration in 1st gear, and added a couple inches extra to make sure. But ... haven't ridden it like this. I refuse to ride a bike that handles like a school bus, so I'm not going down the excessive lowering route, and I'm certainly not lowering more at the rear than at the front, and I don't want mine any longer than necessary to keep the front wheel down most of the time.
Your proposed gearing gives 22% more acceleration than stock. So my thinking is that if the back wheel is 22% further back from the center of gravity, it will have the same "wheelie-prone-ness" as stock. That works out to somewhere around 5 inches longer, plus whatever extra to keep the front down. Offsetting that, making the C of G lower helps by a couple inches.
I know that with mine, just putting a longer chain to get the axle almost all the way back in the adjuster slots made a large difference. Did that a few years ago.
But now, I'm putting mine at +5 to see what happens. Less lowering than yours.
GoFaster is offline
post #3 of 9 Old 01-02-2011, 09:21 PM
with a 64 inch setup and that gearing with a decent 60ft you will be knocking on 5.90's-6.10's consistently from my expierence as im running same setup but a p/c. Ima bout to go up 3 more which is +6 to help with my 60's
seanc520 is offline
post #4 of 9 Old 01-03-2011, 11:19 AM
zx racer's Avatar
ive heard 64-66 inches works very well on the 10's. provided that its a stock motor with the usual boltons.
05 ZX-10R SWB.
zx racer is online now
post #5 of 9 Old 01-03-2011, 11:37 AM
Shorty's Performance
madnessracing's Avatar
How fast have you gone stock wheelbase?
madnessracing is offline
post #6 of 9 Old 01-03-2011, 03:57 PM
KIRK_ADAMS's Avatar
we have mine at 66 and it works great with a stock motor.....but my bike prolly weighs a little less than yours...
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #7 of 9 Old 01-03-2011, 04:50 PM Thread Starter
my quickest time is 9.9991 at 135mph in the 1/4 mile and 6.47 at 115mph in 1/8 mile my best 60ft is 1.64 on swb
post #8 of 9 Old 01-03-2011, 06:25 PM
Try 64 and work yourself out till you find the right spot!
post #9 of 9 Old 01-03-2011, 10:08 PM
damn you have a good hand your 60fts are around what mine are stretched LOL
seanc520 is offline
base gasket edgeflyer Performance and Tech 7 07-15-2009 09:33 PM
vortex gas cap and base hongthaomurphy Vendors deals 1 10-29-2008 09:46 AM
AF base in TX. from Sister in Law maze Pictures and Videos 19 08-27-2007 12:00 AM
VORTEX Gas Cap & Base slav Vendors deals 2 05-14-2006 07:02 PM
