Gen 3: 2008-2010 What times have you ran? - Kawasaki ZX-10R.net
post #1 of 17 Old 07-24-2011, 12:46 AM Thread Starter
Slow10r's Avatar
I was wondering what everyone has ran on their gen 3 bikes, please post mods, and pics with times also.
My bike- 2009 zx10r, -1 tooth up front, jardine gp1 slip on, and pc3 with some generic tune.
best run was 10.3 at 139, and i weigh about 195 suited up, and i am swb also, just lowered 1.2 inches in front, no strap or anything. i was cutting 1.8 as my best 60ft, and it was spinning the shitty sport touring tire i have. 103 degrees out with lots of wind here in az tonight. hoping to get a 9.99 pass on swb in 2 months when it cools down
Slow10r is offline
post #2 of 17 Old 07-25-2011, 12:57 PM
mrbzx7's Avatar
LOR slip on, cats removed from factory header, Flies out, BMC race filter, DP tuned ecu, unmapped Bazzaz, welded clutch basket, 8 over or 63in wb, and gearing is -2 +4 or 15 45. My best pass is a [email protected] in the eighth. What track do you go to out there? I live there for 2 years and blew up my Camaro at Speedworld, I hate that place lol Firebird is good tho.
mrbzx7 is offline
post #3 of 17 Old 07-25-2011, 01:55 PM
BGoodwin22's Avatar
[email protected] w/ a 1.79 60'
2008 ZX-10R - SWB & Strapped
Yoshiura TRC Full Exhaust
K&N Street Air Filter
PCV
Secondary Butterflies Removed
All Short Velocity Stacks
SMOG Pump Removed/Bypassed
Kawasaki Race Intake Cam/Stock Exhaust Cam (Degreed: 110°IN/104°EX)
0.45mm Kawi Head Gasket
Geared -1/+2 (16T/43T)
BT-016 @ 20 psi cold
I've only been to the track 4 times, and twice the track wasn't prepped very well (street night) so I had major traction issues also. Haven't been back since touching the 9's, too lazy too fill out the paperwork for the NHRA comp license I guess. Since then I've installed a quickshifter and lowered the bike almost an inch front and rear. I'm sure the bike is capable of mid 9's. Oh, and I'm about 185 w gear.
BGoodwin22 is offline
post #4 of 17 Old 07-25-2011, 02:17 PM
NinjeR's Avatar
You guys mind posting up the ambient temp and tire pressure when you guys are posting these times?
NinjeR is offline
post #5 of 17 Old 07-25-2011, 03:01 PM Thread Starter
Slow10r's Avatar
i plan to gear it +2 in the rear for a 16/43 set up, i am just debating the stretch, i love having swb and going to hit turns, and still pull good times at the track. i really want to go 9s swb, then go hit some canyons
Slow10r is offline
post #6 of 17 Old 07-25-2011, 03:04 PM
tagger's Avatar
***Edit*** - Feel free to ignore this if you want... totally missed the "Gen 3" in the title (facepalm)
04 ZX10R SWB...
- flies removed
- GiPro ATRE
- Dynojet QuickShifter
- 1 +4
- power commander with tuned map
- stock motor
- strapped & lowered
- Dunlop Q2's - varying from 25-30 psi
- Akra slip-on and mid pipe
This setup has gotten me a 10.000 @ 141 (not even joking - it was a FLAT 10 sec run) with 60's in the mid 1.6X range. Ambient air temp hasn't made much of a difference (except killing my top end by about 2mph) - I run roughly the same whether it's 65 or 95 degrees. (Just pulled a 10.08 last week when it was 90 degrees).
I went out to the track at stock height with a -1 +2 setup for shits and giggles and still pulled a 10.2 with a 1.7X 60'.
I weigh about 225 suited - dropping weight, as this should help a ton (for the track and my health).
tagger is offline
post #7 of 17 Old 07-25-2011, 03:04 PM
BGoodwin22's Avatar
Not sure what the air temp was exactly, but I would guess it was high 60s or low 70s. I am running the stock BT-016s and was at about 20psi cold.
post #8 of 17 Old 07-25-2011, 06:09 PM
zx racer's Avatar
ive been 6.20's in the 1/8 on my swb zx10. best 60ft to date is a 1.58 and i weight 200 pounds suited.
05 ZX-10R SWB.
zx racer is offline
post #9 of 17 Old 07-26-2011, 08:42 AM
Slow Poke
bgmagma10's Avatar
Man truthfully being stretched isn't as bad as you would think on corners. I'm 6 over and I still don't have chicken strips. You'd be surprised how much stretching your bike doesn't hurt your cornering. Only thing you can't really do is hard power out of corners at high revs unless you like drifting. Other than that there's not much of a difference.
bgmagma10 is offline
post #10 of 17 Old 03-22-2013, 08:52 AM
2008 zx10r 4320miles 185-190lb suited on SWB stock height
100% stock with no muffler or boom box still have converter in header..
Need alot more sit time tho...
Reaction .562
60ft 1.806
330ft 4.780
speed 108.93mph
660ft 7.061
speed 137.65
1320ft 10.625
Thanks
wheelies247 is offline
New times for my 3 mil 05 quikgix Strip 32 05-12-2008 06:56 PM
Lap Times grover Track 52 06-02-2007 11:43 AM
Best Times!!!!!! BryanB Race and Stunt 22 05-31-2006 07:18 PM
WHO'S USING NOS and times?? rated zx Performance and Tech 2 11-03-2005 03:52 PM
How many times have you run out of gas? Captain Jack The ZX-10R 56 03-11-2005 12:39 AM
