Gen 3: 2008-2010 What RPM can I launch my SWB 2008 10 at? Bike is fairly stock - Kawasaki ZX-10R.net
post #1 of 23 Old 09-15-2011, 05:19 PM Thread Starter
Buxcustoms's Avatar
Buxcustoms is offline
post #2 of 23 Old 09-15-2011, 06:11 PM
codyc_13's Avatar
Start at 5,000 and work your way up. I was launching mine at 7500 when it was swb.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 23 Old 09-15-2011, 06:25 PM
BANNED
start low at like 3k and work your way up, you can get more aggressive at lower rpms and get out of the hole better and do less wear on the clutch. I launch at 6k and slip the clutch little more, also my bike is lowered and straped which helps a lot.
hellboytt is offline
post #4 of 23 Old 09-15-2011, 06:48 PM
zx racer's Avatar
a good place to start is between 5-6k rpm. also do you have the front end strap ? if not get a strap it helps keep the front end down.
05 ZX-10R SWB.
zx racer is offline
post #5 of 23 Old 09-15-2011, 07:06 PM
a front end strap will SAVE YOUR LIFE LOL
seanc520 is offline
post #6 of 23 Old 09-16-2011, 09:34 PM Thread Starter
Buxcustoms's Avatar
Thanks everyone for the input! I'm going in the morning. High of 68 degrees, bikes gonna run like a beast! It's not strapped, nor do I have lowering links. I'm gonna start at 3,000
I'd rather not go " too" crazy. That way I can get more aggressive on the throttle, than worry about riding out a 12 o'clock wheelie!! Lol
I'll keep this posted
post #7 of 23 Old 09-16-2011, 10:05 PM
bluedevil's Avatar
3000 is to low...practice going full throttle from the start at 4k-5k by pulling in not letting out the clutch while you try...again try to go Full throttle quick..it can be scary on a light short wheelbase 1000 with alot of HP......but remember that monster that want's to bump you off has a off switch and that is called a clutch..pull the clutch in and all that HP is held back...not that simple but hope you get the idea and you will...you control how much HP to the wheel by how much you let the lever out or in...it goes fast and that's the practice part but over time you will get it. ...longer bikes don't worry about this so much as SWB all things being equal.
PS...I tell this to my 12yr old son on his first manual clutch dirt bike this as well it's the same principle.
bloo
bluedevil is offline
post #8 of 23 Old 09-18-2011, 12:38 AM
JLAudio11's Avatar
I'd say start somewhere around 5-6k, I went all the way up to 9500 and backed down to about 8k at the end of running my bike swb.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #9 of 23 Old 09-18-2011, 11:35 PM
mrbzx7's Avatar
Here's some inspiration!
http://youtu.be/PM6SbXpUGKA
mrbzx7 is offline
post #10 of 23 Old 09-19-2011, 12:30 AM
bluedevil's Avatar
yep...but look at his right arm/wrist...it goes FULL throttle....the fast guys know how to use the left arm to compliment the quik right arm/wrist at the same time.
bloo
FS 2008 Stock exhaust Ken968 Parts, Gear and Accessories 4 10-04-2011 05:15 PM
2008 ZX10R Stock Wheels, Samco Hose Kit, Motion Pro Tool, and Stock Levers 4 Sale!!! MagicMavis Parts, Gear and Accessories 7 03-14-2010 11:56 AM
Fairly extreme trailride (dirtbikes) TENN10 Pictures and Videos 2 03-03-2010 11:07 AM
2008 ZX-10R goes 9.23 on a stock motor! madnessracing Strip 37 03-12-2008 08:00 AM
The Benefits of Being Fairly Charismatic and Knowing How to Flirt wicked The Out House 6 07-03-2007 01:44 PM
