What is the best gear set up for a 05 10r for a 1/4 mile - Kawasaki ZX-10R.net
post #1 of 9 Old 08-26-2008, 10:52 PM Thread Starter
BornSinner's Avatar
Images: 19
Send a message via AIM to BornSinner
Im looking for the best gear ratio for a 2005 zx10r stock wheel base but lowered and strapped....
Im at -1 and +2 w/ 520 chain....
Should I stay with this...or go something different
Thanks
BornSinner is offline
post #2 of 9 Old 08-26-2008, 10:55 PM
ZX-10R_Sinner's Avatar
Well +1 more in the rear would put you at a 16/42 from stock, I'd say that's about all the further I'd go for the street. It's up to you as far as top speed and how high of rpms you want when cruising. It's all about what you want, maybe even go 43 or 44 in the rear, which would make for a very quick bike...er ugh...you know what I mean.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #3 of 9 Old 08-26-2008, 10:57 PM
bluedevil's Avatar
Thanks
depends on your mods and Current Times....do you have any info. on that?
bluedevil is offline
post #4 of 9 Old 08-26-2008, 11:58 PM Thread Starter
BornSinner's Avatar
Images: 19
My bike is set up for street....pciii slip--on minor bolt ons
the first time ever on a drag strip.....10.40...trouble with my 60ft....trap speed around 140ish....
I was running to high tire pressure....
I was kinda nervous.....all in all
not bad...IMO
post #5 of 9 Old 08-27-2008, 12:18 AM
bluedevil's Avatar
not bad...IMO
Not bad at all wish you said how much you weigh with gear that does make a difference. I weigh 215lbs with gear and feel I am at my limit now with a 16/40 1st gen 9.97s 145mph Stock wheel base, Slip-on NO PC and no other Mods period other than a cut down seat and 20k miles on the bike.
I would if your fairly light get to the 9s first then start with the 15T front and increase from there with those mods. The guys that have high powered 10Rs(nitrous, extended etc.) seem to stay with the 16T and adjust...SWB with limited mods 15T seems to be the Final limit with maybe a add in the back.
Good luck.
post #6 of 9 Old 08-27-2008, 12:50 AM Thread Starter
BornSinner's Avatar
Images: 19
thanks blue
im 5'11" @ 190ish with gear.....
you think a 15 front....with what is the rear....(stock)?
post #7 of 9 Old 08-27-2008, 01:05 AM
bluedevil's Avatar
thanks blue
Stock for your bike is 17/40 2nd Gen...Stock for a 1st Gen 17/39.
What I am saying is you can get to the 9s with your gearing and once there move to the 15t front and add teeth from there on the rear until it doesn't help anymore unless you do better mods.
Edit. Second Gen owners should respond though to what is the best Gearing with his weight.
bloo
post #8 of 9 Old 09-27-2008, 10:48 AM
Ruthless Racing's Avatar
Images: 9
Thanks
That gearing should be good for your weight, you just need more seat time!!! Just get out there and get in a rythm and work off of that and most of all HAVE FUN!!!!!
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #9 of 9 Old 09-27-2008, 10:46 PM
tone.r's Avatar
thanks blue
Im not stock wheelbase anymore but for my 04 whats working good is 16t 44t, But I been tring a 45t aswell with the 16t 45t i can run 9.84 to 9.88 im 185
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
8th mile/1/4 mile times and mods rated zx Strip 14 06-29-2011 08:39 AM
Race Gear / Riding Gear kawboy69 Parts, Gear and Accessories 8 05-17-2008 06:38 AM
636 1st Gear feels > 998 1st Gear ASIANPRIDE The ZX-10R 43 07-02-2007 11:11 AM
Heads UP Quarter Mile 1/4 mile times olec4 Race and Stunt 9 03-03-2006 06:52 AM
How would you like to run the mile...not quarter mile! ZXMustang The Out House 18 01-19-2006 10:49 AM
