Gen 4: 2011-2015 top of 1st the front end wobbles going down the track.. - Kawasaki ZX-10R.net
post #1 of 16 Old 04-18-2014, 08:36 PM Thread Starter
first time with my 11 zx10r at the 1/8th mile here in West Point ky. I'm running full power, no TC and at the top of first the front begins to wobble. it's done it on the street before i'm wondering if the dampner is set too soft???
only thing done to the bike is a m4 slip on. air pressure in the tire is set to oem specs.
any advice?
YOLO is offline
post #2 of 16 Old 04-18-2014, 08:46 PM
SkyDork's Avatar
Advice about what? It's normal. Lighten your grip on the bars, get your suspension adjusted for your weight, drop the tire pressure slightly, and learn to ride it out.
#WordCrimes
SkyDork is offline
post #3 of 16 Old 04-18-2014, 08:58 PM Thread Starter
I was thinking maybe setting the dampner a little stiffer... isn't that's what it's for?
YOLO is offline
post #4 of 16 Old 04-18-2014, 09:00 PM
harobikes167's Avatar
shift and grab some more throttle
Yes tinker with your damper. Won't hurt anything. If you're afraid to mess with the damper a liter bike isn't for you. But making the damper stiffer doesn't always help and isn't always the solution. Don't hold on all tight like females do when they get scared.
"Never shoot a large caliber man, with a small caliber bullet."
GEN 3: "Stock"
2009 crf 450r
harobikes167 is offline
post #5 of 16 Old 04-18-2014, 09:08 PM
SkyDork's Avatar
The damper is there to prevent RAPID oscillations. Some wiggle/headshake is to be expected and is normal. If you want to adjust the damper slightly, go ahead. But it's not there to mask or increase the steering effort and completely remove all shake from the front. You need to learn to control the throttle without pulling the bars while twisting the throttle. Most headshake and chassis issues are due to suspension set up problems and rider input. As the front gets light, some twitchiness is perfectly acceptable. Know it, learn it, love it.
#WordCrimes
SkyDork is offline
post #6 of 16 Old 04-18-2014, 10:33 PM Thread Starter
this track is an 1/8th, I've ran my 05 ZX10r which was modded a lot more and never had the shake up front even with sprocket change for quicker acceleration. I understand the dampner isn't a fix for all or any shaking especially the oem dampner, I bought the bike used with 2k miles and I was thinking maybe the original owner played with it, possibly loosened it up. I'm not sure which way stiffens it up, i'm no knee dragger so possibly stiffing the dampner for track use could help. just was i was thinking off the top of my head, but i asked for advice and i guess im just gonna have to keep practicing.
YOLO is offline
post #7 of 16 Old 04-18-2014, 10:40 PM
fireman69's Avatar
By taking out preload (adding rider sag) you'll find that the front tire stays in contact better and thus you'll have better stability.
At least that works well for road racing.
fireman69 is offline
post #8 of 16 Old 04-19-2014, 04:06 AM
xezerax's Avatar
If you're talking about the steering damper I believe its clockwise to tighten it up, just adjust it one way and wiggle the bars you'll be able to tell if its getting tighter or looser.
xezerax is offline
post #9 of 16 Old 04-19-2014, 08:19 AM Thread Starter
Thanks
YOLO is offline
post #10 of 16 Old 04-19-2014, 08:24 AM
SkyDork's Avatar
Yes, if you're looking at the damper knob, turning it clockwise stiffens it.
#WordCrimes
SkyDork is offline
Damn to much lift on top end. Kicked out of the track. Interceptin Strip 10 07-11-2012 08:16 AM
1st Track Day this week end Fred-R Track 16 10-22-2010 04:53 PM
front tire wobbles flthy1 Performance and Tech 10 06-17-2009 10:12 AM
Help.. Front end quishy under heavy track braking sunbear70 Race and Stunt 33 10-13-2007 08:32 PM
1st Service & Lifting front end slide Performance and Tech 17 10-15-2004 09:57 AM
