Gen 5: 2016- Too tall? - Kawasaki ZX-10R.net
 1Likes
  • 1 Post By Kawasaki Brad
post #1 of 8 Old 07-27-2019, 09:24 AM Thread Starter
Too tall?
Hello everyone. I have a question I hope you can help me with. I have a 2017 ZX10 which is stock except for a Graves slip on. My issue is this. When I’m at the quarter mile track shifting from 2nd to 3rd the front end either starts to comes up or starts to shimmy real bad..this is at about 115 mph. Because I’m 6’3 (205 lbs) I can’t lean forward too far to get more weight on the front. Any ideas on how to get this bike under control? I launch well...it’s just the end of the track where everything starts happening.
Bronca714 is offline
post #2 of 8 Old 07-28-2019, 06:37 PM
Kawasaki Brad's Avatar
Wheel balanced and everything aligned and torqued in the front end? Ride height and sag set? You may need to respring and keep the rear up which will help keep the front down.
Try dropping the forks in the triple tree's by something small like 1/8 inch. It may change your rake just enough to solve this problem.
Guarf likes this.
Kawasaki Brad is offline
post #3 of 8 Old 08-01-2019, 10:13 PM Thread Starter
I’ll try a fork strap to see if that helps. I didn’t want to do a swingarm extension just yet as I want to keep it a street bike for the most part.
post #4 of 8 Old 08-02-2019, 11:47 AM
nakedinseattle's Avatar
stiffer steering damper. or try a different "line" down the track, maybe it's bumps in the track.
Shut up and ride.
Nun sacciu, nun vidi, nun ceru e si ceru durmiv
nakedinseattle is offline
post #5 of 8 Old 08-03-2019, 04:26 PM
put your chin on the front tank cover and support your weight with your feet. I have very agressive gearing (-1/+4) and i have no problems keeping the front down outside of 1st gear launching at 12,000.
Longer chain and move the wheel all the way to back of the swingarm adjuster.
You also probably need a stiffer rear spring for your weight.
AFM #705 | youtube | instagram | facebook
Please give some love to my 2019 Sponsors!
Daredevil Motorsports | Amsoil | SPY Optic | GoPro
JayBoCC2 is offline
post #6 of 8 Old 08-04-2019, 09:23 PM
The Pace
scout's Avatar
Don't worry about getting below the screen; weight on pegs and body forward and grip tank hard with knees while staying upper body loose as possible. If front is doing weird, as you report, then the bike is telling you to get off...body is in fear mode.
Riding whatever is interesting...even a straight stupid line, I guess.
Track is too short to need the screen, unless heavy head wind, I guess; a lot does rest upon physical conditioning, which I often forget to include on this site as so few ride, but if head feels too much wind at 130-140, outta of shape, for sure.
scout is offline
post #7 of 8 Old 08-05-2019, 11:45 AM
What scout said. Light hands on the bars, it may just be you holding on too tight which also makes the problem worse
Shut up and ride.
post #8 of 8 Old 08-06-2019, 08:08 PM Thread Starter
Thanks for all advice everyone. I really appreciate it. I went to the Kawasaki dealer Saturday....and came home with a 2019 ZX14R after trading in the ZX10. Now I’ll have room to tuck AND I’ll still use the advice you all gave me. I’ll wait till the break in period though at 1000 miles.
