Gen 2: 2006-2007 tire size and model - Kawasaki ZX-10R.net
post #1 of 14 Old 09-23-2011, 12:21 PM Thread Starter
ricozx10r's Avatar
Images: 13
Send a message via AIM to ricozx10r
tire size and model
gettign rid of my 2ct which tire is good to get? shinko but what model? and will a 200 fit on a 07 zx10r stretched with the 525 chain?
gen 1 10r current bike..
06 10r lowered and stretched, flashed, strapped, full brocks. sold
07 Full Muzzys exhaust,-1,4+, lowered/stretched 6in,k&n filter, powercommander,riffle man insert, block off plates, removed secondaries. sold
ricozx10r is offline
post #2 of 14 Old 09-23-2011, 12:35 PM
zx racer's Avatar
can't beat the Shinko 003 U soft for the $$$ its a lil on the heavy side but it will get the job done.
05 ZX-10R SWB.
zx racer is online now
post #3 of 14 Old 09-23-2011, 01:17 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
SHENKO....Never see them on my bike..
craig_sez is offline
post #4 of 14 Old 09-23-2011, 01:48 PM
PatrickG's Avatar
Images: 15
Look for a Shinko "hook-up" at this site.. http://www.chaparral-racing.com/Prod...69-874650.aspx
They are alot lighter then the U-soft and you don't need to run a 200 unless you are turbo'd or running NOS.
Otherwise a 190 or even a 180 is more then enough, the thinner the tire the better. Because it is alot less weight that your engine is trying to spin. I run a 180 on my 09' zx10r and 03' gsxr1000 and never have problems with hooking up.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #5 of 14 Old 09-23-2011, 02:27 PM
BANNED
go with 180 hook up, less weight, same traction.
hellboytt is offline
post #6 of 14 Old 09-23-2011, 07:38 PM Thread Starter
ricozx10r's Avatar
Images: 13
i plan on running nos
post #7 of 14 Old 09-23-2011, 08:36 PM
BANNED
180 and 190 will have about close to the same area contacting the ground, but the weight will make big difference since it's since it's like 18 inches or so from the center.
post #8 of 14 Old 09-25-2011, 07:59 PM
Gen2 Ripper
neverendingmods's Avatar
Shinko Stealth 003 U-soft 190 if street and drag racing. For ONLY THE STRIP, get the Shinko Hook Up 190 50 17 as nothing comes close to it's traction and it is light as hell. But not to be used on the street as it is just way too soft both compound and the sidewall. For some street riding and some track use get the Stealth 003 usoft, Can't beat that tires grip aside from a $250 Michelin. Can get 2 003 U-soft tires for that kinda $.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #9 of 14 Old 09-25-2011, 08:01 PM Thread Starter
ricozx10r's Avatar
Images: 13
roger that i know what ill be getting then :)
post #10 of 14 Old 10-17-2011, 10:56 PM Thread Starter
ricozx10r's Avatar
Images: 13
Which michellin model?
tire size 180 vs 190 jm981_4343 The ZX-10R 7 05-23-2011 07:09 PM
Chicken Hawk Racing Standard Model Tire Warmers ridersdiscount Riders Discount 2 08-25-2010 09:59 AM
Tire Size kiloalpha Performance and Tech 19 03-27-2008 12:56 PM
Tire size superman10r Performance and Tech 12 12-04-2007 08:11 PM
tire size ? mylegacy412 The ZX-10R 17 07-28-2007 12:29 PM
