Time slip input - Page 2 - Kawasaki ZX-10R.net
 7Likes
post #11 of 31 Old 06-28-2015, 11:31 PM
mixedboitoo's Avatar
I also have a gen 3 and I back dated my clutches to the 04-05....Dwayne said if u have the big judder metal u don't need the 2 judder springs put back in...just to save u some time....I'm Alison having some issues with my clutch....feels funny...engages a lot quicker than before but I know the stack height is taller but its a pain to find that sweet spot....good luck
mixedboitoo is offline
post #12 of 31 Old 06-29-2015, 06:43 AM
gazx10's Avatar
vp fuel cans have a coded date on the can label right under the fuel type. there's a series of three different numbers right under the mr12 designation. first one is part #. second is weight of can and third is date of manufacture. it will read like 100/15 which means it was produced the 100th day of 2015. nothing wrong with 5 gal can unopened for 3-4 months. but once opened about 60 days max for best results. nothing like it pretty fresh, but nothing aged. vp also recommends storing mr12 in a airtight metal can only. we figure about 3 cans for the race season.
gazx10 is offline
post #13 of 31 Old 01-07-2016, 04:29 PM
Blue- did you end up getting your clutch sorted out and the jerkyness to stop?
Patrick- What benefit does putting a gen1 clutch into a gen3 have?
I'm going to be buying a clutch basket with the hays big rivet kit and will need a new set of clutches to put in it. Wanting to educate myself before I spend the $$ for a new setup.
What about the brocks clutch mod? If i'm starting from scratch and replacing the whole basket, is this a necessity for drag racing?
thanks fellas
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, side winder, BMC race, lowered, stretched,-2/+4, velocity stacks, little spray, nos mini.....
MORE TO COME
medicbaldwin is offline
post #14 of 31 Old 01-07-2016, 08:19 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
thanks fellas
Yes a while back I adjusted it a little bit and it solved the problem. I put the brocks clutch mod in the same time as the cycle concepts drag pack and hd springs. It was night and day difference for me ( for the better) but I'm not really sure what made the biggest difference.
65, pos
8.67 @ 154mph
Blue08 is offline
post #15 of 31 Old 01-08-2016, 08:22 AM
gazx10's Avatar
my gen 1 had stk. kaw plates and steels, stk judder plate and .090 clutch spring shims made from 12mm home depot washers oblonged to fit pressure plate correctley under the stk. springs. smooth as butter, lasted 3 yrs. still dont have gen 2 right wirh dragpac after trying several spring/shim combos. it holds, but has always been abrupt, sorta in or out launching.higher the spring pressure worse it is. running stk. shimmed springs now but still not smooth. even obvious just pulling off slowly. think ill go back to the complete oem gen 1 setup . got a good chassis but 60 ft. still not where it should be from clutch. clutch is only thing keeping me from reaching my goal. got sold on dragpac from listening to others, but my experience from over the years is oem plates/steels has worked best. launch style has a lot to do with how a hub holds up, unless ur brutal that gen 3 hub with welded rivets should hold, just ck it ocassionally as u should with any hub dragracing. riders are different, clutches same way. just have to find what suits u. oem clutch will hold a lot of hp with spring pressure upped, hard to beat imo.
gazx10 is offline
post #16 of 31 Old 01-08-2016, 09:24 AM
Thanks for the info guys. Big help!! Since a complete clutch setup whether OEM or dragpak is about the same cost, i'm planning to go with a dragpak with HD springs.
'08 10R, Lime/Black
MORE TO COME
post #17 of 31 Old 01-08-2016, 03:06 PM
Slow Poke
bgmagma10's Avatar
I really doubt your clutch is slippin man. 28mph on the back half is right at what mine did.
bgmagma10 is offline
post #18 of 31 Old 01-11-2016, 10:18 AM
zx racer's Avatar
Good choice! Dragpak is only clutch i ran that lasted. Think you got gen3 get the basket welded while your at it and back date clutch to gen1.
05 ZX-10R SWB.
zx racer is offline
post #19 of 31 Old 01-12-2016, 12:43 AM
I'm buying a big rivet upgraded basket which is already welded.
'08 10R, Lime/Black
MORE TO COME
post #20 of 31 Old 01-12-2016, 12:54 AM
bluedevil's Avatar
With Gazx10 on this one over the years yes it's possible to get great times on dragpak I done it myself but still feel OEM is still the BEST ...can't argue with ZXRACER though he has some of the best times ever recorded on a first Gen 10R but he is also the cheapest dude too so wonder how many pacs he goes through at the same time... .....j/m racer
bloo
____________________________________________
Sent from My Computer via DSL mid to low service Firefox updated version, sometimes wireless sometimes Wire from the garage depending on connection speed.
bluedevil is offline
Gen 1: Slipping Clutch Time Slip bluedevil Strip 9 02-27-2012 02:10 AM
The Old Days time Slip LOL bluedevil Strip 14 05-09-2011 08:12 PM
Winter time, commissioning time, time for some mods, right? Clark6592 The ZX-10R 16 12-07-2009 01:36 AM
Advice: Long time rider, 1st Time Track Day elsoloscuro Track 6 08-10-2007 03:44 PM
Time slip for my 04 ZX10R GARSZX10R The ZX-10R 8 06-16-2004 02:51 PM
