Taking the 10 to the Track Friday - Kawasaki ZX-10R.net
post #1 of 30 Old 06-09-2008, 12:52 PM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
Hey everyone. I am taking the 10 to the track this Friday. I have front end strps that I am going to use for the first time. My bike is at stock height ( front and rear ). I did not drop it yet with my Muzzy Rear links b/c I am thinking about using adjustables for the rear. Will it be ok to just strap the front end while leaving the rear at stock height? Should I take it as low as I can go with the strap? Also what will I be able to launch at once strapped and how much fast can I release the clutch to go WOT once the front is strapped? I am on SWB
Thanks
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 30 Old 06-09-2008, 03:18 PM
Post Whore
1killer1liter's Avatar
Images: 11
You will want to air down your rear tire for sure. The powers hook well, but they are not consistent. Just use the strap to lower the bike in the front. Try not to crank down on it too much or you have a good chance at blowing the fork seals (I did). Try launching around 5k-6k rpm until you get the feel for it. You will have to play with the clutch until you get the feel for it.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #3 of 30 Old 06-09-2008, 03:25 PM
Shorty's Performance
madnessracing's Avatar
It will be easier if you lowered the rear too!! and its easy to put the rear links too just use a jack and put it under the shock!!
madnessracing is offline
post #4 of 30 Old 06-09-2008, 03:55 PM
solo4092's Avatar
Wish I was going. Give it hell for me man.
solo4092 is offline
post #5 of 30 Old 06-09-2008, 04:06 PM Thread Starter
OneSLOW10's Avatar
I never replaced a rear shock or did any work back there like messing with the links, but a shop told me you have to take the tail apart and the lowers the lift the rear up with something like a engine hoist then put a jack under it. Is ALL that bullshit? b/c I wasn't sure. They said 2 hrs and I was like nah. Thats why I haven't installed the Muzzys. Plus I thought if that's true if I ever want to go from 1 1/4" drop to the next drop ( 2" ) I will have to do all that crap.
post #6 of 30 Old 06-09-2008, 04:06 PM Thread Starter
OneSLOW10's Avatar
=thanks
post #7 of 30 Old 06-09-2008, 04:07 PM Thread Starter
OneSLOW10's Avatar
How low in tire pressure should I go ?
post #8 of 30 Old 06-09-2008, 04:14 PM
Post Whore
Images: 11
Start at 28-30 psi, but no lower than 18-20 psi considering the power has a different carcass and may break the bead or slide around at the big end.
post #9 of 30 Old 06-09-2008, 04:30 PM Thread Starter
OneSLOW10's Avatar
so PP's aren't so hot for the track ah?
post #10 of 30 Old 06-09-2008, 06:19 PM
Post Whore
Images: 11
Out of the other tires I have used, they hooked the best. They just take a long burnout to get the carcass hot enough to be sticky. Far and away the best tire is the shinko u-soft. I have 2 seasons on my 180 and its nowhere near dead. Not bad on the street either.
Best numbers at the track as friday night quikgix Strip 3 05-05-2007 08:54 PM
Is it friday yet? S.ga.rider The Out House 14 12-07-2006 04:51 PM
At the track on friday night 1killer1liter Race and Stunt 4 09-07-2006 12:21 PM
Friday at the Gap king-tony The ZX-10R 100 05-02-2005 09:50 PM
going to the track taking both racers scottymizt Race and Stunt 8 07-31-2004 08:45 PM
