Gen 4: 2011-2015 Surprise!!! Look what I found out what works in my clutch! - Kawasaki ZX-10R.net
post #1 of 41 Old 03-30-2013, 09:40 AM Thread Starter
PatrickG's Avatar
Images: 15
Well after much talk with a few other members. I thought I'd give it a try and it worked perfectly!
Part number is 13089-0003, its the OLD Gen1 first clutch spring plate.
You have to use a few more 2.6mm steel plates in the clutch stack but other then that. I had no problems at all last weekend, go 8 passes in 3.5 hours and it never slipped or went away on me.
I'm loading up now to go run today also.
Hopefully some better Gopro videos will come later on!
Name:	Gen4 clutch s.jpg
ID:	186354   Click image for larger version
Name:	Gen4 clutch 1s.jpg
ID:	186362   Click image for larger version
Name:	Gen4 clutch 2s.jpg
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #2 of 41 Old 03-30-2013, 12:54 PM
SpazOnaZX's Avatar
I don't have a Gen 1 OR 4, but that's some cool shit. :) Rep sent for checkin' it out. :)
SpazOnaZX is offline
post #3 of 41 Old 03-30-2013, 01:49 PM Thread Starter
PatrickG's Avatar
Images: 15
Lol thanks.. but it will work in all generations of zx10s. I'd try it out in my 09' but my wife won't let me Screw with her clutch since she's finally getting used to it.
PatrickG is offline
post #4 of 41 Old 03-30-2013, 02:03 PM
Post Whore
-Op-'s Avatar
thats awesome!! How are the Gen 4 clutches supposed to hold up? I know Ive always heard that Gen 1 clutches are the ones to get, but just curious to hear a comparison to the G4
-Op- is offline
post #5 of 41 Old 03-30-2013, 05:56 PM
thundercoupe9's Avatar
that judder springs also works in 09+ zx6r lol
thundercoupe9 is offline
post #6 of 41 Old 03-30-2013, 09:09 PM
matt d's Avatar
Lots of GSXR guys use the ZX10R judder plate too. The 2011 ZX10R race manual recommends using it as well. After today's trip to the track, I am going to throw mine in too because my clutch is not holding up well in the upper rpm's. I ended up getting a 04/05 clutch setup, with the judder spring, set up at 53.6mm. Can't wait to get back and try it out.
matt d is offline
post #7 of 41 Old 03-30-2013, 09:27 PM Thread Starter
PatrickG's Avatar
Images: 15
I think all generation 1-3 clutches hold up better then the Gen4. The Gen4 clutch is up high and not really suited for dragracing like the previous models. Just my opinion.
And from personally experience it holds true. My 09' clutch holds up to a helleva lot more runs then my Gen4 does.
PatrickG is offline
post #8 of 41 Old 02-27-2014, 11:48 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
Good info!
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #9 of 41 Old 02-28-2014, 12:27 AM
badexample's Avatar
I love that forum! Thanks man! I'll do that!
“Ride like you are invisible.”
badexample is offline
post #10 of 41 Old 02-28-2014, 07:03 AM
Joel's Avatar
So what part does that replace then?
Very interested in this.
Joel is offline
Hayes Machine Works ZX10 Clutch Mod hellsrazor The ZX-10R 4 03-03-2013 09:46 AM
Surprise from the wife. 10rhawkdrvr Pictures and Videos 19 03-27-2009 06:38 PM
Thai Surprise bkkninja The Funny Pages 1 08-08-2007 12:32 AM
surprise more birthdays Big Daddy The Out House 10 04-21-2006 05:29 PM
no surprise..... 05ZixxR The Out House 3 10-12-2005 09:22 AM
