Gen 1: 2004-2005 Strip Again! - Kawasaki ZX-10R.net
post #1 of 14 Old 11-19-2011, 02:51 AM Thread Starter
Post Whore
-Op-'s Avatar
Strip Again!
New personal best guys. 1/8 mi runs today.
R/T: .590
60 FT: 2.025
ET: 7.203
MPH: 110.29
Stock Height, SWB, no straps, Boz Gild, PCIII, BMC Air Filter, Mirrors Removed, ZG Sport Touring Windscreen. Est. ~200lbs suited.
-Op- is offline
post #2 of 14 Old 11-19-2011, 01:03 PM
Certified SLOW
nolaZX10's Avatar
Congrats, gettin' those times down takes practice but it feels good when you can see improvements.
What gearing and track you running at?
nolaZX10 is offline
post #3 of 14 Old 11-19-2011, 01:25 PM
zx racer's Avatar
congrats on the new personal best man have you thought about lower it ? bc she's got alot left in her if you set her up right for the track.
zx racer is online now
post #4 of 14 Old 11-19-2011, 06:04 PM Thread Starter
Post Whore
-Op-'s Avatar
It just felt good cuz that was another 2 tenths off of my best time, last time I went. Focused a lot on getting her WOT and the clutch out faster.
Stock Gearing for now. Ive strongly considered lowering, strapping, gearing and stretching. I just wanted to see if I would be able to afford going often enough to race, and at least set goals to reach before I would step seriously into the direction. I definently want straps the next time I go, and the 1/5 throttle insert is going in.
Track is setup as 1/8mi at Qualcomm Stadium. Ambient temps last night were in the 50s I believe. Altitude is approximately 100Ft.
As always, any tips and help are GREATLY appreciated. Id love to hit 7 flat if I could as currently set up.
-Op- is offline
post #5 of 14 Old 11-19-2011, 06:08 PM Thread Starter
Post Whore
-Op-'s Avatar
This is the video to my 7.2 run. Guy I was running is a slammed and stretched, I believe geared, and on a Shinko drag radial (non-slick). I actually got him on R/T by .004, but his 60ft killed me. He went 6.9 @ 92. If I could bring the 60ft, I would have gotten it.
-Op- is offline
post #6 of 14 Old 11-19-2011, 08:38 PM
zx racer's Avatar
i highly suggest lowering the rear, straping the front and throwin some gear to her for starters. maybe try -1 and see where your at. when i was swb i was -1 +2 crossing the finish line top of 3rd and i weight 200 pounds if that helps. best pass to date was [email protected] with a 1.58 60ft.
post #7 of 14 Old 11-19-2011, 09:30 PM Thread Starter
Post Whore
-Op-'s Avatar
I definently want to get to do all of those things for sure. I just cant afford to do it all at once (college student, go figure). I was thinking about playing with a rear sprocket since its cheap and easy to swap. Whats the biggest you can go without needing a new chain? I might just spring for the straps, adjustable lowering links and a bigger rear sprocket and see where that takes me, especially considering it would only be like $150.
-Op- is offline
post #8 of 14 Old 11-20-2011, 01:15 AM
Certified SLOW
nolaZX10's Avatar
You can get front sprockets cheaper than rear, but you will need an impact to get that front sprocket nut off.
nolaZX10 is offline
post #9 of 14 Old 11-20-2011, 02:21 AM Thread Starter
Post Whore
-Op-'s Avatar
Yeah, Id just have to buy an impact first was the thing. How far up in the rear is possible on stock chain length?
FWIW, I just did my 1/5 throttle insert. WTF?!?!?!
Anybody wanna ride a f*%kin Kawi WSBK?!?!
-Op- is offline
post #10 of 14 Old 11-20-2011, 02:41 AM
Certified SLOW
nolaZX10's Avatar
Not sure, I went -1 when SWB.... didn't touch the back until I stretched it. You are much better off going -1, borrow somebody elses impact. It will push your WB back a little, going up in the back will make your wheelbase shorter.
nolaZX10 is offline
Pic of 08 10 at the strip TX-954 Strip 20 03-21-2008 12:41 AM
NWS best strip i ever saw edouble Adult Content - Photos / Videos - N.W.S. 2 11-18-2007 08:11 PM
*NWS* Strip RickRoush03 Adult Content - Photos / Videos - N.W.S. 18 02-14-2006 09:16 PM
3rd try at the strip Chucky Race and Stunt 12 09-20-2005 06:04 AM
9.92 at the strip kawiman88 The ZX-10R 9 04-03-2004 06:59 AM
