Stock Motor with MR12 - Kawasaki ZX-10R.net
post #1 of 17 Old 03-05-2015, 03:18 PM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Hey guys, im looking to finally get my bike tuned after going back and fourth on what i want to do with it for over a year now.. I picked up a multi hub and im looking to get the bike tuned on 89 for the street and MR12 for the strip. anyone have any other recommendations on fuel. Its stock engine just pretty much all bolt ons, ill be adding a bmc filter and short stacks too before the tune.
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 17 Old 03-05-2015, 04:50 PM
SpazOnaZX's Avatar
I've heard a lot of good things about MR12... hopefully Gaz will chime in on it. Just keep it sealed/fresh. :)
SpazOnaZX is offline
post #3 of 17 Old 03-05-2015, 05:02 PM
gazx10's Avatar
mr12 is the s--- throttle position tuned, and just s--- untuned. be sure to check can date, 6 mos about limit for max gains. u will be surprised at gains from 6k to rev limit. stock ignition timing best, advanced will not work with this fast burn fuel. both our tens made 10+ in midrange and 8 up top over custom tuned 89 pump gas. they just rip on mr12. let us know how u come out. done right, great power adder. best fuel period for ur bike racing.
gazx10 is offline
post #4 of 17 Old 03-05-2015, 05:30 PM
C3L1CA's Avatar
I picked up 3mph on mr12 at the track over 87. 'Tuned' both via the autotune.
Just don't let it sit in the gas tank very long.
C3L1CA is offline
post #5 of 17 Old 03-06-2015, 05:25 AM Thread Starter
Blue08's Avatar
Thanks guys. The bike will be tuned by Schnitz and yeah I plan on getting a hand pump and draining the think every night after the track.
65, pos
8.67 @ 154mph
Blue08 is offline
post #6 of 17 Old 03-06-2015, 06:16 AM
gazx10's Avatar
last 4 years ive left mr12 in tank 2-3 days at cup races with no problems. i do drain as soon as possible after use. i use a simple small clear hose tie wrapped to a piece of straightened coathanger that easily reaches back bottom of tank to siphon. clear lets u see fuel in line. i replace with pump gas, crank and idle a couple of minutes. mr12 exhaust has strong distinct smell, easy to determine when pump has flushed the system by exhaust. ryan will do u a good job. let us know how it comes out.
gazx10 is offline
post #7 of 17 Old 03-06-2015, 08:57 AM
Speed Freak
garth285's Avatar
garth285 is offline
post #8 of 17 Old 03-06-2015, 09:11 AM
serialize's Avatar
With a correct tune the MR12 will have power gains and also a nice smooth/consistent throttle feel. It was pointed out not to leave in the tank for long, and from my experience at the track you flush it out with pump after a race (especially if there is any epoxy in the head/etc, but you have stock motor so not as bad).
Like bikes ......... Like Kawasaki ........
1996 ZX6R, 2003 ZX636, 2009 ZX6R, 2011 ZX10R
2006 R6-R, 2007 R6-R, 2010 FZ1
2005 CRF250R, 2011 KTM 350sxf
serialize is offline
post #9 of 17 Old 03-06-2015, 09:19 AM
C3L1CA's Avatar
I just use a cheap hand pump (think it was $4 or less) from Home Depot that I used to get the gas out of the tank, worked really good for what it was.
I've heard that people have left it in the tank for a week with no problems and I'v also ready people have had problems leaving it in for just a night but I think there was other issues there. I left mine in over night with no ill effects that I can tell.
I'd just want to drain it as soon as you can and run pump gas through it. Like said MR12 has a very distinct smell and you can tell once the bike is running on mostly pump gas simply by the smell. I miss the smell of mr12, it's been a long winter!
C3L1CA is offline
post #10 of 17 Old 03-06-2015, 06:28 PM Thread Starter
Blue08's Avatar
thanks for the info guys, before i get it tuned anything else you guys would reccomend doing before hand, other than bmc filter. I have a flashed ecu (opens the secendaries, rev to 13.5k and no top speed limiter on the gen 3's), pcIII, full brocks alienhead, geared -1+4, and ill be giving it a fresh oil change. looked into all short stacks but it looked like a few people here didnt have good results with it.
65, pos
8.67 @ 154mph
Blue08 is offline
Trade: Gen 4 built motor for stock motor and $ garth285 Parts, Gear and Accessories 4 08-01-2012 08:35 PM
stock motor times Jeffpac53 Strip 26 03-06-2012 10:53 AM
8 sec stock motor 08 10r !! rad10r Pictures and Videos 3 07-17-2008 02:36 PM
WTB 07 or 08 GSXR 1000 STOCK motor, low miles,stock and complete Ruthless Racing Wanted: Buy or Trade 0 05-09-2008 09:46 PM
looking for 04-05 head or stock motor sweetride10r Wanted: Buy or Trade 2 09-25-2007 06:04 PM
