Solid Strut?? - Kawasaki ZX-10R.net
post #1 of 9 Old 04-13-2010, 10:54 PM Thread Starter
^^No Bike Bum^^
cbolton69's Avatar
Send a message via Yahoo to cbolton69
Solid Strut??
a few weeks ago i bottomed the 10 out and popped a small hole in my oil pan.. i stiffened the rear shock top and bottom the its hardest settings. at the track, my tag is about 6" above my tire and when i launch it bends my tag up...
as a temp. solution i build a solid strut at work and replace my rear shock all together (wow what a weight diff.)..
does anyone else run a solid strut all the time??? pros - cons???
is there a trick to making the rear shock tight enough to keep me from bottoming out even if i carry a rider???
fyi.. im extended 12" over stock, lowered 1" in front and 2"(i believe) in rear.
thanks guys
05 ZX-10R (stolen Dec. 3, 2010)
04 ZX-10R (SOLD)
"Violence may not be the best option...... But it's still an option"
"It's Better to die on your feet than live on your knees"
"Those afraid of pain will never know glory"
cbolton69 is offline
post #2 of 9 Old 04-16-2010, 08:45 PM
At that length, you will bottom out even with the best top $$ shock. A strut is a good idea but a bad idea. You have to decide if you want a street bike or a race bike. The strut is a good solution for what you have but not the best for the track. Hit up a T&T day at the local strip, the first pass or two will tell you!!!
TinkerBell is offline
post #3 of 9 Old 04-16-2010, 11:29 PM
BlkCasper's Avatar
also for street riding look at getting a stiffer spring for rear shock matched up for you & riders weight. I had to get a 500lb spring for my zx9, lowered and stretched 8 over stock do 2 up riding. Spring are about 120-200 bucks depending on where u get them from. I used a racetek rear spring.
BlkCasper is offline
post #4 of 9 Old 04-17-2010, 09:17 AM
JLAudio11's Avatar
Definitely need a heavier spring. The harder you start to push it launching it at the track you'll see the limitations of the strut on a street tire as you wont have any momentum going down to help plant the tire. It will most likely spin. Now if you were on a slick and bars it'd be a different story. I'm having a similar issue and am looking into a spring or just raising the back up. One trick that a lot of guys use is swapping to a stock busa spring. My buddy has a spare zx14 shock but I haven't had time to try the spring from it out yet.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #5 of 9 Old 04-26-2010, 07:10 PM
clutch master's Avatar
If you're going to spend time at the strip, first thing you need is a cut/and or flat oil pan. Your shock just could be worn out, try another one and stiffn it up. The worst thing you can do is strut it, you'll spin all day. Im way longer than you and I only have a stock shock, a straight link and a flat o-pan ofcourse. Well you know it also depends on how much you weigh, if you're a heavy setter, then you may need a modified shock, or busa shock like someone suggested.
The clutch is your friend
clutch master is offline
post #6 of 9 Old 04-26-2010, 07:20 PM
JVT
You can add spacers to the top also!!!
JVT is offline
post #7 of 9 Old 04-26-2010, 08:03 PM
quikgix's Avatar
I have 3 hole lowering links mounted on the second hole,I loosened the spanner nuts all the way to the top of the shock, set the compression to the lowest setting and set the rebound full on.I dont have any issues bottoming out,Im 185 in street clothes!It just scrapes the lower fairings.
Now what
quikgix is offline
post #8 of 9 Old 04-27-2010, 10:16 AM Thread Starter
^^No Bike Bum^^
cbolton69's Avatar
Thks for the input. .. the problem with the stock shock is the wife can ride with me.. I picked up a visa shock this weekend to try..
Who did u use for flattering ur pan... I got a 10 and 14 to get done.
04 ZX-10R (SOLD)
post #9 of 9 Old 04-27-2010, 12:08 PM
quikgix's Avatar
Stock pan on my junk
Now what
quikgix is offline
where to get a strut? demented racing The ZX-10R 6 01-28-2009 11:17 AM
WTB 06 adjustable strut!! SAkI Wanted: Buy or Trade 0 04-17-2008 11:32 AM
running a strut turbohomda Race and Stunt 0 07-01-2007 02:30 AM
Solid or Stranded Wire? IcePick06 Performance and Tech 6 07-09-2006 11:01 PM
Any solid info on delivery dates? marco383 The ZX-10R 61 03-02-2004 11:07 PM
