So I went to the track last night. - Kawasaki ZX-10R.net
post #1 of 25 Old 03-08-2009, 08:30 PM Thread Starter
07ZX10RJoe's Avatar
I went to the track last night and couldnt get a good pass for nothing. I changed my front sprocket from a 15 to a 16 and also strapped the front end. My best pass was a 6.73 @ 115 with a 1.8 60ft. I know I'm having a problem getting wot in the first 60 feet. I need to order the 1/5 throttle mod. Also It feels like something is keeping my bike from rolling very well on its on. Kind of a dragging feeling. Could that be clutch issues? I also have trouble getting my feet back on the pegs to shift without wasting time. I would like to get an air shifter but not really sure where to mount a tank and how to supply it with air.
07ZX10RJoe is offline
post #2 of 25 Old 03-08-2009, 08:42 PM
zx10sander's Avatar
zx10rjoe in ur pic ur bike looks great is there any post with pics of your bike?
zx10sander is offline
post #3 of 25 Old 03-08-2009, 08:59 PM Thread Starter
07ZX10RJoe's Avatar
Thanks man. Ive posted in a couple other threads. I'll have to find them. I'm waiting to be able to get out and clean it up and get some better pics.
post #4 of 25 Old 03-09-2009, 12:01 PM
Shorty's Performance
madnessracing's Avatar
Is the bike stock wheelbase?
madnessracing is offline
post #5 of 25 Old 03-09-2009, 12:03 PM
10R_Havens's Avatar
It looks like it is SWB based on his avatar, but a 1.8 60' SWB is pretty good...
10R_Havens is offline
post #6 of 25 Old 03-09-2009, 02:19 PM
Reason Im asking is cause if its SWB I wouldnt recommend the 1/5 throttle mod but I recommend a lof of seat time and you will the numbers drop dramatically!!
post #7 of 25 Old 03-09-2009, 06:40 PM Thread Starter
07ZX10RJoe's Avatar
Yeah I know I need more seat time but I am not getting to wot until almost half track and thats wasting a whole lot of time. Ive got the front strapped and it doesnt try to jump up but will slowly rise. I'm still waiting on my extensions to get here.
post #8 of 25 Old 03-09-2009, 07:19 PM
codyc_13's Avatar
half track, you should be able to get wot right out of the hole, when my bike was stock wheelbase, just lowered and strapped, i would be wot right out of the hole and just use the clutch to control the power, it would 60' 1.71 and go 9.90 no problem, im no expert but i race with experts every weekend, they have always told me never control the power with the throttle, always use the clutch, you just have to be smooth with the clutch the whole time, if your smooth until the last bit of the clutch is out it wont wheelie on you, But when you get choppy with the clutch is when it wheelies on you, you will start to notice that you can get out of the clutch alot faster if its smooth, if you dump the last little bit of the clutch on a stock wheelbase bike its going to come up no matter what.
codyc_13 is offline
post #9 of 25 Old 03-09-2009, 07:43 PM
Micron05rr's Avatar
Originally Posted by codyc_13 View Post
half track, you should be able to get wot right out of the hole, when my bike was stock wheelbase, just lowered and strapped, i would be wot right out of the hole and just use the clutch to control the power, .
It is a bit intimidating at first to go to WOT right off the bat but, I like this method as well because it frees up attention to concentrate on the smooth release of the clutch. As far as the bike having a dragging feeling a few things that come to mind are chain that's too tight, maybe your pistons in the brake calipers are getting hung up and not allowing them to fully retract which could cause excessive brake drag. When you get the opportunity, get your bike on a stand to see how easily the wheels spin by hand. I do know that when the weather is really cold, I have to make sure to keep the temps up before the run otherwise, I have issues similar to what you are describing because the oil is so thick that it messes with the clutches operation. I used to have issues getting my feet up in time for the shift to second but, as I have gotten more seat time, that problem has gone away. I had an airshifter mounted on my bike for nearly a year but, could never get comfortable leaving my feet off the pegs as I went down the track so, I am back to footshifting and have run my best times to date with just the DJ quickshifter and foot shifting. Not sure what kind of seat time you have but, like others said, there is no substitute for practice.
2005 ZX6RR
[email protected] MPH
10.49 video http://www.youtube.com/watch?v=w_KQhDSCvQA
Micron Serpent Full System-BMC Race-PC3
Kit ECU-Dynojet Quickshifter
Strapped-Short Wheelbase
www.mpsracing.com
Micron05rr is offline
post #10 of 25 Old 03-09-2009, 07:46 PM
STW
Went to the track last night Uwan Strip 5 11-02-2008 06:13 PM
Pics & Videos from the track the other night Playboy07 Strip 12 08-07-2008 09:53 AM
Best numbers at the track as friday night quikgix Strip 3 05-05-2007 08:54 PM
At the track on friday night 1killer1liter Race and Stunt 4 09-07-2006 12:21 PM
Took the hahn to the track last night smithabusa Pictures and Videos 7 04-21-2005 05:00 PM
