Single front brake - Kawasaki ZX-10R.net
post #1 of 10 Old 11-07-2015, 10:37 AM Thread Starter
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Single front brake
This winter I'm looking to do some weight reduction and probably gonna lose a front rotor I know it's not much but rotational weight its something better than nothing. Looking into a light weight battery and maybe a set of bst's if I can get myself to pull the trigger. I do street ride a little big but usually put less than 500 miles a year on just easy street riding no street racing. The guys who only run one how do you like it? And any other weight saving ideas I'm open to listen to. (Also I am aware that braking will change so I don't need to hear that)
65, pos
8.67 @ 154mph
Blue08 is offline
post #2 of 10 Old 11-07-2015, 01:29 PM
TechX's Avatar
I use to run a single disk on my super comp drag bike never had any problems. I did get some fade when hauling it down from 150 plus mph but always had enough power to get it stopped.
TechX is offline
post #3 of 10 Old 11-08-2015, 09:49 AM
gazx10's Avatar
pulled front rotor, caliper, swapped to lithium battery on 07, lost 13 lbs. change to jri shock 4 more lost over busa shock. bike before weighed 410 on digital scales at cup race with a little gas. reweigh this coming wknd at race. pretty accurate rule of thumb is 20 lbs = one tenth.
gazx10 is offline
post #4 of 10 Old 11-08-2015, 07:17 PM Thread Starter
Blue08's Avatar
Thanks guys. Gaz that's what I thought it was 20 lbs = .1 I'm trying to get into the 8s next spring still foot shifting. I have the whole set up to run co2 but trying to save weight it doesn't make sense to do all this then Stick a 20oz bottle and ad the weight right back so I think I'm gonna sell the regulator and buy a compressor and use the built in tank in my arm. I was only able to get out twice this year so I was a little disappointed.
65, pos
8.67 @ 154mph
Blue08 is offline
post #5 of 10 Old 04-04-2016, 10:38 PM
You might be surprised to find the bike harder to ride hard off the line by taking weight off the front wheel (i.e., removing a rotor). I actually picked up 2 tenths by adding 10# to my front axle. No way would I pull a rotor and move the CG back...WHERE the weight is will be more important than how much you take off. Just keeping your legs bent in front of your body rather than dragging them behind you is worth a tenth or two as well.
zx10racer is offline
post #6 of 10 Old 04-05-2016, 10:56 AM
Slow Poke
bgmagma10's Avatar
I decided not to pull one rotor on my 14, but I will tell you, the ONLY thing that ever concerns me when riding a bike with one rotor is burnouts. When the track is hot and your tire is hot, it wants to push the front REALLY bad when doing a burnout. That could just be the heavier weight of the bikes I was riding too. Just wanna give you a heads up.
bgmagma10 is offline
post #7 of 10 Old 04-05-2016, 07:15 PM Thread Starter
Blue08's Avatar
Thanks guys, actually fort about this post. I decided to leave it on. Need to work on my 60' more I decided. Still trying for 8's and I've been in the high 1.5's and best of 9.2x mostly 9.3 passes so once I get my 60' in the 1.4x I'll look at making changes to help out.
65, pos
8.67 @ 154mph
Blue08 is offline
post #8 of 10 Old 04-05-2016, 07:42 PM
zx racer's Avatar
Blue wats your wb and gearing
05 ZX-10R SWB.
zx racer is offline
post #9 of 10 Old 04-06-2016, 01:03 PM Thread Starter
Blue08's Avatar
I'm -1+4 sitting at about 64" ZX
65, pos
8.67 @ 154mph
Blue08 is offline
post #10 of 10 Old 04-06-2016, 07:01 PM
zx racer's Avatar
Ok wat rpms are you leavin at? Did you ever get a shifter?
05 ZX-10R SWB.
zx racer is offline
gen1 brake rotors calipers and front brake master cylinder BUGSY_MONTANA410 Parts, Gear and Accessories 3 06-13-2013 01:44 PM
Gen 3: Stock Front Brake Calipers With Brake Pads $100 Shipped 1fast10r619 Parts, Gear and Accessories 0 04-29-2013 11:50 PM
Gen 4: Looking for a Set/Single front & rear Wheels kxmike87 Wanted: Buy or Trade 3 11-04-2011 03:17 PM
Single front rotor thoughts turbo10 Performance and Tech 13 03-08-2009 04:45 PM
WANTED ASAP!!! 04-05 single front brake rotor.... garth285 Wanted: Buy or Trade 9 06-03-2008 08:14 PM
