Shifting to 6th on the nitrous!!!!! - Kawasaki ZX-10R.net
post #1 of 11 Old 01-22-2011, 05:53 PM Thread Starter
stretched10R's Avatar
Ok I have a mps airshifter setup and Im running a 40 shot on a stock 2006 zx10.I set the delay in the kill box large. Ever since I did the nitrous it hasnt wanted to shift to 6th gear.It shifts fine on motor runs,but on spray it wont go for shit. Im thinking about doing a RC's Race Cut Transmission. Im tired of not running the numbers it should because of a shifting problem,any reviews on that tranny set up from them?? Thanks
Born with that MAD KAW DISEASE!!!!!
stretched10R is offline
post #2 of 11 Old 01-22-2011, 06:43 PM
09zx10miami's Avatar
How long is the kill duration you set?
****Giiiiiiiiittttttuuuurrrdooonnneee****
09zx10miami is offline
post #3 of 11 Old 01-22-2011, 06:52 PM
shifting
The reason why it does not want to shift is because you are spinning the tire. That is why it shifts fine without the nitrous because you are not spinning. You can get the transmission race cut to help, but if you are spinning it will still shift inconsistently. Mike.
880turbo is offline
post #4 of 11 Old 01-22-2011, 07:29 PM
gazx10's Avatar
nitrous cut
call rc or mark at r&d motorsports, they offer special nitrous cuts, above race cut, and shift drum mod for nitrous at 40 shot and above. r&d has been in the race transmission business forever and they are the best. im sure u got this covered, but ive seen std., not high pressure, bottles drop too much pressure to shift 6th after 5 shifts.
gazx10 is offline
post #5 of 11 Old 01-22-2011, 07:51 PM Thread Starter
Thanks man, Na my pressure is good,I have the Adams arm and the tanks in that,120psi and after a pass im still at about 90psi
post #6 of 11 Old 01-22-2011, 07:52 PM Thread Starter
Thanks man,but I dont think tire spin is my problem, Its in 5th and 6th gear and Im running a shinko hook up,stretched only 8 over.
post #7 of 11 Old 01-22-2011, 09:34 PM
tank zx10r's Avatar
Images: 52
i pump my air shifter up to around 140-145 and have no problem since i did that hope that helps
R.I.P Shannon T. Hightower July 29, 1971 August 4, 2007
All Kawasakis aren't created equal
tank zx10r is offline
post #8 of 11 Old 01-23-2011, 07:33 AM
tone.r's Avatar
+1 bump it up some check your wires on your coils aswell my bike was doing the same thing, check your airshift bracket make sure you have alittle play, Man fix that fast because if you dont you will bend a shiftfork hope this help
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #9 of 11 Old 01-23-2011, 07:35 AM
tone.r's Avatar
I pump up to 145-160
Tone.R {checkmate}
tone.r is offline
post #10 of 11 Old 01-25-2011, 08:06 PM
ke2012's Avatar
I used to had that same problem back in the day, on my R1 with a 60 shot, same as above bottle pressure @130 and kill time set right and you should be good. Also, i had a window switch set up, so that nos selonoid was kill right before the shift point...maybe something to consider also.
ke2012 is offline
What RPM are u shifting at Mad_man Strip 15 07-23-2009 10:13 AM
shifting wpbzx-10 Strip 15 03-01-2008 03:49 PM
Shifting to first (06 10R) YZF The ZX-10R 17 05-09-2006 09:51 PM
Shifting LoCoZx10R The ZX-10R 50 05-04-2006 03:48 AM
GP shifting ? ? packetsmurf The ZX-10R 32 03-14-2005 01:50 PM
