rookie drag racer with a beast - Kawasaki ZX-10R.net
post #1 of 14 Old 04-06-2014, 04:17 PM Thread Starter
wick1984's Avatar
Hey guys, just wanted to stop by and say hey.. i ride an 04 zx10r--7"extended, lowered about2", bmc filter,yoshi trs. pc3, butterflies removed, exhaust servo elim., short stacks, geared-1&+3. vortex rearsets inverted for more legroom----i nick-named it "EL coocooi"--in spanish, it means the boogeyman----cause it scares the crap outta me :), definatley the fastest vehicle ive driven....growing up from klr650's, suburbans, and vw bug's.
i plan on getting an air shifter, and a 30-40 dry shot kit....just saving up for a radiator(leak)
i'm 6'6" and about 300lbs suited.--i'm a biggen
before all of the mods, i ran her in november in stock form it ran 11.25 @130mph, 2.0-60' ---i had a real problem with popping the clutch, then it bogs.
im hoping i will break into the 10.999 mark(will die a happy man)
im also planning on changing gears and running it at the texas mile in october
once i drop in a new radiator, plan on heading back to the strip this friday for a lil test and tune.....if anyone is in the san antonio area that would be willing to show me some pointers, that would be cool!
anywho...thanks for listening to my rant...will keep u guys posted on how i do
wick1984 is offline
post #2 of 14 Old 04-06-2014, 04:35 PM
zx racer's Avatar
Welcome sharp bike! your big guy on bike that dont make lot torque you gona have gear the piss out it for it to leave,60 good i suggest -2 on the front see where your at chances are you gona need more gear but -2+3 would be good startin point.
05 ZX-10R SWB.
zx racer is offline
post #3 of 14 Old 04-06-2014, 05:39 PM Thread Starter
wick1984's Avatar
cool, thanks for the tip. will the 15 tooth front be to tight of radius for the chain? or will it just increase wear?
wick1984 is offline
post #4 of 14 Old 04-06-2014, 07:05 PM
Blue08's Avatar
Location: Mentor on the Lake, Ohio/Broke at a dragstrip
Good looking bike 10.999 shouldn't be a problem at all even with like a 1.8 60 foot. A few people are running a 15 tooth I'm sure but I'd ad more to the rear instead..
65, pos
8.67 @ 154mph
Blue08 is offline
post #5 of 14 Old 04-07-2014, 01:02 PM Thread Starter
wick1984's Avatar
coool. i think im just going to go both routes and get a 15t & a 44/45 tooth rear to play around with in the 1/4 or 8th.
gonna have to go back down on the rear when i run the mile though--
also, quick question- in the 1/4- what tire psi's should i run?, im on a michellin pilot rear for now, till she wears down, i'll get something more suitable.
thanks for all of the help guys!!
wick1984 is offline
post #6 of 14 Old 04-07-2014, 03:56 PM Thread Starter
wick1984's Avatar
Also, i just had my radiator pressure tested---its leaking in about 15 different places, they said its due to electralasys(sp?)
so if any of you have an old radiator laying around, will be willing to buy it off of you.
wick1984 is offline
post #7 of 14 Old 04-07-2014, 04:12 PM
zx racer's Avatar
Gen1 have LONG 1st gear so -2 is must unless you have 1st gear mod and helps save on clutches you want have to slip clutch as much. since your stretch 20psi would be good start might have lower it more if you havin tire spin but you wanna run much psi possible without havin traction issues.
05 ZX-10R SWB.
zx racer is offline
post #8 of 14 Old 04-07-2014, 05:41 PM
I run 15 tooth fronts for years now never had an issue. U doing good job for a big guy congrats bud
beanedisel is offline
post #9 of 14 Old 04-07-2014, 10:48 PM
Same here 15/44 on my 07 race bike and 15/42 on my 05 street bike. Bout to go to a 44 on the 05
2007 ZX10R -- CAN'T GET RIGHT
(Current Drag/Street bike)
2005 ZX-10R (Current Street bike)
2006 636 ZX6R- Stolen
Just your below average Kaw. Grazing in the pasture with all the other turds. :-)
Jbundrick is offline
post #10 of 14 Old 04-08-2014, 10:04 AM Thread Starter
wick1984's Avatar
cool, thanks for all of the tips/comments guys!!! (keep 'em coming)
as much as i dont want to, i decided to lose a bit of weight myself. at least 10-20 lbs.
ooohh man, cant wait to get her out and start practicing!!
wick1984 is offline
For Sale: Zx10 powered custom dune buggy / drag racer TMY10ER eBay & Auction Links 1 11-13-2011 06:30 AM
The Top 10 reasons to date a Drag Racer madnessracing Strip 2 10-05-2009 08:54 AM
Lady drag racer need help..... zx10ladydragracer Race and Stunt 14 10-11-2007 10:51 PM
Beginer Drag Racer TX06'10r Race and Stunt 17 12-15-2006 03:53 PM
Orient Express' Newest ZX10 Drag Racer Rob Hughes The ZX-10R 5 08-13-2004 05:51 AM
