removing the secondary butterflies on drag bike - Kawasaki ZX-10R.net
post #1 of 6 Old 02-02-2012, 02:11 PM Thread Starter
I have a 2008 zx10r, strip only bike, after looking at different threads, do you guys think removing the secondary butterflies would help at all on a strip only bike. Some of the other threads said it helps more in mid range but not up top. Just wanting to know what you racers think and know. The bike will be running this race season no filter, open header, pcv with custom map, msd launch master, shift light and hopefully pingel electric shift. All info appreciated.
Bustar is offline
post #2 of 6 Old 02-02-2012, 02:18 PM
Speed Freak
garth285's Avatar
yank em!!!!!
If you can and have the $ send the ECU out to get flashed, they pull abour 4* timing up top so your missing out on some power and faster times!
garth285 is offline
post #3 of 6 Old 02-02-2012, 05:39 PM
zx racer's Avatar
pull em out and switch out the 2 tall stacks in the middle for 2 short outer ones.
05 ZX-10R SWB.
zx racer is online now
post #4 of 6 Old 02-02-2012, 11:26 PM Thread Starter
thanks for the quick answers i'll be taking them out when its torn apart i the next couple weeks
Bustar is offline
post #5 of 6 Old 02-02-2012, 11:33 PM Thread Starter
Learning alot about the zx's, totally different beast than I was used to, always dragged Harleys before, thanks again for all the info you put out, where would be a good place to send my ecu to garth
Bustar is offline
post #6 of 6 Old 02-04-2012, 10:55 AM
gazx10's Avatar
take the sec. rod also and epoxy the tb's, take it all out.
gazx10 is offline
Removing secondary butterflies bullet4 The ZX-10R 2 01-08-2012 08:14 PM
will removing secondary flies help with drag racing. codyc_13 Strip 1 04-10-2010 04:53 PM
removing secondary butterflies M109R Performance and Tech 3 03-17-2010 08:43 PM
Removing the Secondary Butterflies Zuperman Performance and Tech 15 04-01-2009 10:00 AM
Questions on removing secondary butterflies on TB??? on1whl Performance and Tech 14 01-13-2006 06:21 AM
