removing radiator fan - Kawasaki ZX-10R.net
post #1 of 16 Old 03-14-2011, 08:57 PM Thread Starter
codyc_13's Avatar
do any of you drag racers have your radiator fan removed? just curious because my new exhaust doesnt clear my fan and instead of dremeling my bracket i was wondering if i could just remove the fan altogether.
My bike is a drag bike only and NEVER sees the street
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #2 of 16 Old 03-14-2011, 08:58 PM
Speed Freak
garth285's Avatar
do it, will save 2 lbs :-)
I used to not roll around with it on my 04 10r during the cooler months of the year. As long as you dont get her to hot you'll be fine
garth285 is offline
post #3 of 16 Old 03-15-2011, 01:39 AM
KIRK_ADAMS's Avatar
I will have no cooling system this year...1 gallon of antifreeze is like 8lbs I think...
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #4 of 16 Old 03-15-2011, 02:06 AM
bluedevil's Avatar
The fan only hits when over 210degs....if your running that hot the bike should not be running in the first place the ZX10Rs run best at 160deg anyway.
bloo
bluedevil is offline
post #5 of 16 Old 03-15-2011, 02:18 AM
Balogiannis's Avatar
Send a message via MSN to Balogiannis
Ι have my fan removed and I use the bike on the streets also,just not in heavy traffic.
You should be fine in a drag only bike.
Balogiannis is offline
post #6 of 16 Old 03-15-2011, 11:48 AM
What are u removing?
1 gal water=8.3
1 gal anti=9.3
water boils at 212
06green is offline
post #7 of 16 Old 03-15-2011, 01:56 PM
pmason718's Avatar
Send a message via AIM to pmason718
I have a fan for sale is anyone ever needs one, new
pmason718 is offline
post #8 of 16 Old 03-15-2011, 02:00 PM
Racejunkie05's Avatar
im reading about everyone shaving the fan from their bike then i read this
Racejunkie05 is offline
post #9 of 16 Old 03-15-2011, 03:07 PM
KIRK_ADAMS's Avatar
1 gal water=8.3
1 gal anti=9.3
water boils at 212
I'm removing the fan, radiator, all the hoses, water pump...everything to do with the cooling system.
post #10 of 16 Old 03-15-2011, 03:44 PM
So I suppose a dry block bike is OK to start it,go to burn out area,perform a burn out,line-up and make a pass?
Removing 06 swingarm SAkI Performance and Tech 1 10-03-2008 07:58 PM
removing air box codyc_13 The ZX-10R 7 03-16-2008 07:15 PM
Removing gas cap -No Key Bigtuna660 The ZX-10R 35 11-04-2007 06:00 PM
Removing Cat what map will i need ? Speedyj Performance and Tech 7 11-16-2006 01:18 AM
Removing your CAT smason5 Performance and Tech 19 08-20-2006 10:32 PM
