Random Stress Crack ?? - Kawasaki ZX-10R.net
post #1 of 16 Old 03-22-2013, 11:25 PM Thread Starter
Darmentle's Avatar
Exclamation Random Stress Crack ??
So i lost a bolt randomly on one of my case covers on the right side. I have never touched that bolt and then when i went to replace the bolt i noticed that there was a fat stress crack. my bike has only 5500 miles on it never down . Never touched that side . What do you think for a solution. sucks i haven't even made a full pass on it yet and i was suppose to go to the track this weekend.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 16 Old 03-23-2013, 12:07 AM
SpazOnaZX's Avatar
That's a crazy place to develop a crack. 8/
Check you starter clutch, gears, and rods in there and see if anything is fishy. If everything checks out you might have just had a flawed case. It is possible that the bolt came loose on that idler shaft and starting it -might- have let enough play in there to give it leverage to damage the case, but that doesn't seem to likely. It honestly just looks like a crappy case or an over-torqued plug/bolt along the way. :(
SpazOnaZX is offline
post #3 of 16 Old 03-23-2013, 12:44 AM Thread Starter
Darmentle's Avatar
Thanks i will just JB weld for now. and replace the bolt just wanted to make sure it wasn't some sort of issue.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #4 of 16 Old 03-23-2013, 03:15 PM Thread Starter
Darmentle's Avatar
So now i am getting a clunking sound about 1 out 5 starts it goes clunk like something is binding up. I took off the cover and inspected the gear and area button no marks or anything looks fine.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #5 of 16 Old 03-24-2013, 03:16 PM
gazx10's Avatar
that's not a stress crack, pretty sure that clunking and binding and crack are related. need to pull full cover, clutch hub and inspect everything from crank gear behind hub to starter. break off one of the case tabs that also positions and secures starter gear shafts on case side and u will need total teardown and cases. cause of clunking/binding needs to be determined and fixed.
gazx10 is offline
post #6 of 16 Old 03-24-2013, 03:56 PM
Supercharged Mod
Deflection in that cover could be allowing the idler gear to misalign. It wouldn't surprise me if that's the source of the clunking - and the abnormal stresses from the missing bolt are the source of the crack in the first place. It's even possible that the shaft deflection is pulling the gear teeth out of engagement.
Take the covers off and make sure the engine spins over evenly without any odd noises. If you've got mechanical jamming (incorrect valve timing, carbon build-up on the pistons hitting the head, etc) it could very easily overstress the starting motor and cause that crack and the nasty noises.
GoFaster is offline
post #7 of 16 Old 03-24-2013, 07:25 PM
SpazOnaZX's Avatar
Take it all apart. Check everything. Twice. :)
post #8 of 16 Old 03-30-2013, 12:38 AM Thread Starter
Darmentle's Avatar
Alright check it out tomorrow. let you guys know.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #9 of 16 Old 03-30-2013, 11:17 AM Thread Starter
Darmentle's Avatar
Ok guys i got inside the cover and checked everything out. Looks good no metal shavings no damage to any gears. I turned the motor over by hand several times and it sounds good no crazy sounds. Once it starts it runs great i took it to the drags last weekend and ran it. And the hotter the bike got the more frequent the clunking starts became. So i replaced the battery thinking maybe it had a bad cell and it wasn't engaging the starter completely. So i don't know maybe when i spayed it on the dyno it messed something up. Drags are tonight again i was hoping to go . What you guys think?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #10 of 16 Old 03-30-2013, 12:05 PM
Jarhead398's Avatar
I was wanting to goto the drags tonight but I have a clunk sound on takeoffs after installing 905 race sliders. I prefer to figure out and fix the problem before I put that link of stress on my bike & brake something.
Jarhead398 is offline
crack kuziken10r Adult Content - Photos / Videos - N.W.S. 43 05-16-2012 08:06 PM
Gen 2: Battery stress again Ninja man77 General Motorcycle Discussions 8 07-20-2011 08:31 PM
Stress. Brandon The Out House 23 01-18-2010 09:46 AM
Stress....how do YOU cope with it? okie The Out House 36 06-21-2007 06:11 PM
Old School rainy day stress relief Kickaho Pictures and Videos 9 03-21-2006 09:18 PM
