radiator - Kawasaki ZX-10R.net
 2Likes
post #1 of 19 Old 02-08-2019, 04:43 AM Thread Starter
radiator
Probably not the best place to put this thread, but it is drag race specific. I have a Woolsey sidewinder exhaust and my OE radiator won't clear. Looking for either an alternate radiator from another bike that will fit or a used grudge style rad for my gen 3.
'08 10R, Lime/Black
Flashed ECU, PC5,WBC, custom shift light, shifter w/co2, side winder, BMC race, lowered, stretched,-2/+4, velocity stacks, little spray, nos mini.....
MORE TO COME
medicbaldwin is offline
post #2 of 19 Old 02-08-2019, 09:32 AM
SpazOnaZX's Avatar
Do you need it shorter top-to-bottom? You could have a shop shorten the end tanks and take as many rows out of it as you need to...
SpazOnaZX is offline
post #3 of 19 Old 02-08-2019, 11:09 PM Thread Starter
Yeah, top to bottom is too long. Was looking for a better alternative than hacking my rad apart
'08 10R, Lime/Black
MORE TO COME
post #4 of 19 Old 02-09-2019, 02:18 PM
SpazOnaZX's Avatar
...not many better options. You could build one from scratch, but it's a PITA to find curved cores.... a junkyard/ebay radiator that you modify would probably be cheaper in the long run. Can you just kick out the bottom of the radiator a bit and use a longer support brackets? I've done that once or twice to fit things that really don't belong behind radiators.....
post #5 of 19 Old 02-09-2019, 06:42 PM
C3L1CA's Avatar
That's a good idea see it you can just push it out a bit if its close. I haven't installed my brocks side sinder on my gen 4 but it looks like it did come with a new radiator bracket.
Shortening it seems like a good weight savings lol
C3L1CA is offline
post #6 of 19 Old 02-10-2019, 03:11 AM
michael4012's Avatar
It depends how much you need to move the radiator out i suppose i have used washers between the bracket & block once with a longer bolt but to far and you'll fowl the fairing when you come to fit that
michael4012 is offline
post #7 of 19 Old 02-11-2019, 08:50 AM Thread Starter
Think I’ll mock something up to see what I can fit in there for cooling.
Hopefully I can find a rad from a different bike that is shorter and will fit
'08 10R, Lime/Black
MORE TO COME
post #8 of 19 Old 02-13-2019, 03:26 AM Thread Starter
I've found a radiator that I think will suit my needs. Looks like a Gen2 busa rad will work, as long as it fits width wise. I appears to be about 3/4" shorter than my minimum distance measured.
Hoping to get feedback from a radiator company on ebay.
Should anybody have a gen2 busa rad available to grab some measurements I'd sure appreciate it. I mainly need overall width and height of the rad itself, not so much with mounting tabs.
Thanks-
'08 10R, Lime/Black
MORE TO COME
post #9 of 19 Old 02-14-2019, 04:35 AM
BGoodwin22's Avatar
Terry Mcintosh shortened my Gen3 radiator several years back. Maintained factory fan and coolant hose inlets/outlets. Never had a problem with exhaust clearance, but my front end is pretty much as low as you can go plus offset triple trees and the tire clears no problem now.
BGoodwin22 is offline
post #10 of 19 Old 02-18-2019, 10:45 PM Thread Starter
Thanks for the info. I’ll reach out to a few people/places and get quotes for the work
'08 10R, Lime/Black
MORE TO COME
Radiator fan pushed against radiator mile6453 The ZX-10R 10 03-26-2017 02:59 PM
06 Radiator Different than 04/05 Radiator??? Vonstallin Performance and Tech 2 12-29-2006 01:31 PM
need frame sliders and radiator screen? Zxrider The ZX-10R 11 07-16-2004 01:13 PM
Radiator Guard? RUNNINHORN The ZX-10R 8 05-30-2004 06:43 PM
Radiator Guard hayabusa57 The ZX-10R 5 05-25-2004 11:34 PM
