quickshifter question - Kawasaki ZX-10R.net
post #1 of 16 Old 03-15-2008, 10:52 AM Thread Starter
wpbzx-10's Avatar
Send a message via AIM to wpbzx-10
I installed a quickshifter yesterday and went to test it nothin happen when i go to shift it my self it will give me the kill time but it wont shift it self. It is turned on thu the power commander. i tryed to set it low to see if it would work but dint work. do i have to be at full thottle to make it work or should it work all the time. thank you for any help.
wpbzx-10 is offline
post #2 of 16 Old 03-15-2008, 02:07 PM
silversv1k's Avatar
Images: 44
only at full throttle
silversv1k is offline
post #3 of 16 Old 03-15-2008, 05:56 PM Thread Starter
wpbzx-10's Avatar
i just tryed at full throttle and it did not work any other ideas, thank you
wpbzx-10 is offline
post #4 of 16 Old 03-15-2008, 10:50 PM
tank zx10r's Avatar
Images: 52
i have mine set at a kill time of 75 and make sure you have the push not the pull if you have regular shift
R.I.P Shannon T. Hightower July 29, 1971 August 4, 2007
All Kawasakis aren't created equal
tank zx10r is offline
post #5 of 16 Old 03-15-2008, 11:41 PM Thread Starter
wpbzx-10's Avatar
yea i got the push one. I tired it like 5 times on the road and nothin happen. I set it at low rpms to see if it woould work and i trid high rpms full thottle and nothin.
It is set at 65 should i try making it higher or is there something else. thank you
wpbzx-10 is offline
post #6 of 16 Old 03-15-2008, 11:49 PM
silversv1k's Avatar
Images: 44
id try it higher, then find out what works and go less from there i think mines at like 80-95 ms i think
post #7 of 16 Old 03-16-2008, 11:13 AM
tank zx10r's Avatar
Images: 52
you have to be wide open and dont set it so low, also when you put the disk in it will ask you to enable or disable the quick shifter
post #8 of 16 Old 03-16-2008, 12:55 PM Thread Starter
wpbzx-10's Avatar
ok i put it up to 85 ms and did a few wide open runs down the road and nothin happen. had it set for 9000 rpms. i allready enableed it. so i have no idea what it is.
wpbzx-10 is offline
post #9 of 16 Old 03-16-2008, 07:55 PM
dirt ninja's Avatar
Images: 9
Did you have to add a rod that they supplied or did you use your stock shift linkage rod?
dirt ninja is offline
post #10 of 16 Old 03-16-2008, 08:22 PM Thread Starter
wpbzx-10's Avatar
i used the rod that they gave me
wpbzx-10 is offline
ever see this dj quickshifter? hesaves0211 Performance and Tech 11 08-11-2007 10:54 PM
dynojet quickshifter question logmaster Performance and Tech 7 06-27-2007 09:17 PM
Quickshifter question 1killer1liter Performance and Tech 28 10-10-2006 09:13 PM
quickshifter question speedfreak Performance and Tech 11 09-19-2005 09:58 AM
quickshifter biker_larry1000 Vendors deals 0 05-23-2005 09:31 PM
