quarter mile time help!! - Kawasaki ZX-10R.net
post #1 of 103 Old 08-01-2011, 12:27 PM Thread Starter
dp0289's Avatar
I have a 04 zx10 lowered strapped pc3 stretched 9 inches and geared 16/43. My fastest time at the track was 10.92. I weigh 215 suited. Guy ran my bike and ran a 10.20 weighing 175. And he said the bike bogged off the start. I'm thinking I need a bigger rear sprocket. Any ideas???
dp0289 is offline
post #2 of 103 Old 08-01-2011, 12:39 PM
codyc_13's Avatar
Give us a time slip with
60'
330'
1/8
1/8 mph
1000'
1/4
1/4 mph
We need to see numbers to help you, you should be running ALOT faster than that.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #3 of 103 Old 08-01-2011, 01:33 PM Thread Starter
dp0289's Avatar
r/t .350
60' 2.012
330-4.939
1/8-7.250
mph-107.23
1000-9.228
1/4-10.921
mph-129.84
dp0289 is offline
post #4 of 103 Old 08-01-2011, 02:47 PM
codyc_13's Avatar
Where are you racing at?
Your 60' and mph are not good. You should easily be able to get 1.6 60', stock wheelbase I was 60'ing 1.71s. Gearing will help, but seat time will help even more.
With a 6 inch stretch my 60' are in the 1.52 range and my 330 is 4.0x.
Another problem is your mph, it should at LEAST be in the high 130s or low 140s.
Sponsored by:
Vaughan Racing
Synthetic Shield
Moline Bar
codyc_13 is offline
post #5 of 103 Old 08-01-2011, 02:50 PM
zx racer's Avatar
Originally Posted by dp0289 View Post
r/t .350
60' 2.012
330-4.939
1/8-7.250
mph-107.23
1000-9.228
1/4-10.921
mph-129.84
yea you should runnin way faster times than that. your bike is capable of runnin 9's all day long. i would work on your 60 and 330 times to start and lookin at your trap speeds your mph is off alot. wat rpms are you launching at and wat rpms are you shifting at also ?
05 ZX-10R SWB.
zx racer is offline
post #6 of 103 Old 08-01-2011, 04:05 PM Thread Starter
dp0289's Avatar
Launching at 8000 and shifting at 12500.
should I try a 45 tooth rear sprocket.
dp0289 is offline
post #7 of 103 Old 08-01-2011, 05:05 PM
zx racer's Avatar
thats the same rpm i launch and shift at. im 200 pounds and im geared -1 +2 best 60ft to date is a 1.58 make sure you gettin dat clutch out asap while going full throttle. you can throw that 45t on the rear to see if that will help tho.
05 ZX-10R SWB.
zx racer is offline
post #8 of 103 Old 08-01-2011, 05:15 PM
Certified SLOW
nolaZX10's Avatar
I wouldn't bother with the sprocket. To be honest, it may help a little but you have larger problems than gearing. Practice practice practice. Focus on getting that 60 and 330 down. If it bogs, slide the clutch longer.
Best 1/4mi ET: 8.98 @ 147 (stock motor, no turbo/nitrous)
nolaZX10 is offline
post #9 of 103 Old 08-01-2011, 06:09 PM
Slow Poke
bgmagma10's Avatar
Excatly! And get WOT asap!
bgmagma10 is offline
post #10 of 103 Old 08-01-2011, 06:54 PM
ricozx10r's Avatar
Images: 13
Send a message via AIM to ricozx10r
^ what he said. i listened to him and went from 10.8 to 10.0s in no time on my 10r :)
gen 1 10r current bike..
06 10r lowered and stretched, flashed, strapped, full brocks. sold
07 Full Muzzys exhaust,-1,4+, lowered/stretched 6in,k&n filter, powercommander,riffle man insert, block off plates, removed secondaries. sold
ricozx10r is offline
20 years: Less than .5 second gain in quarter mile??? Plecostomus The ZX-10R 16 07-12-2017 05:52 PM
08 ZX10 Quarter mile Gearing? 347 tony Strip 27 08-31-2009 07:24 AM
Heads UP Quarter Mile 1/4 mile times olec4 Race and Stunt 9 03-03-2006 06:52 AM
How would you like to run the mile...not quarter mile! ZXMustang The Out House 18 01-19-2006 10:49 AM
Quarter mile times splatmaster Performance and Tech 8 08-26-2005 05:09 PM
