Gen 3: 2008-2010 Popping noise from clutch - Kawasaki ZX-10R.net
post #1 of 7 Old 06-13-2011, 07:22 PM Thread Starter
mrbzx7's Avatar
I noticed a loud thud or pop when I released the clutch yesterday, but only on a good launch and at the last 20% of lever travel. My 60's aren't spectacular they were only 1.54, 1.55,1.56, but I went 1.60 twice and didn't hear a thing. The bike is a '09 and the basket has been welded. Has anyone heard anything like this?
mrbzx7 is offline
post #2 of 7 Old 06-14-2011, 10:26 AM
zx racer's Avatar
are you runnin hd springs ? maybe check with schntiz or brock to see if they make a clutch mod to eliminate that noise.
05 ZX-10R SWB.
zx racer is offline
post #3 of 7 Old 06-15-2011, 04:11 AM Thread Starter
mrbzx7's Avatar
Its got Barnett springs, I did change to the 2nd gen swingarm recently. I'm gonna pull the clutches and check out the basket real good
mrbzx7 is offline
post #4 of 7 Old 06-15-2011, 08:13 AM
PatrickG's Avatar
Images: 15
Keep us updated. I just started racing my 09' and am curious to hear what u find out. Also who welded ur basket? R u talking about the aluminum rivets? I've heard those are a trouble spots when racing.
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #5 of 7 Old 06-15-2011, 08:41 AM
gazx10's Avatar
rivets are steel, yeah, better pull that basket, they can break even welded.
gazx10 is offline
post #6 of 7 Old 06-15-2011, 08:59 AM Thread Starter
mrbzx7's Avatar
I haven't welded the rivets, I just welded the inner basket together to disable the slipper function. I did this myself not to difficult, but I am a mechanic for a living.
mrbzx7 is offline
post #7 of 7 Old 06-15-2011, 09:23 PM Thread Starter
mrbzx7's Avatar
I got the clutches out and they were really dry! Only the bottom plates showed signs of oil. The basket looked ok and the welds on inner hub are still in good condition. I'm thinking they were getting grabby and thats the noise I heard, at least I sure hope its that simple. The stack height is low too 52.73mm and spec is 53.5
mrbzx7 is offline
Clutch Hub Noise? marktor Performance and Tech 5 02-19-2009 03:49 PM
Clutch noise afskypilot Performance and Tech 2 08-28-2008 09:18 PM
06 Zx10r Clutch/gearbox Noise (need Help) 06ZX10R-TRINI Welcome Newbies! 10 10-11-2007 09:52 PM
Clutch noise? Help! lunitk Performance and Tech 18 11-23-2006 03:32 AM
Clutch making noise when engaged. JIKSER Performance and Tech 1 10-14-2005 10:07 AM
