Gen 2: 2006-2007 Perfect suspension set up for drag racing - Kawasaki ZX-10R.net
post #1 of 8 Old 06-01-2014, 01:36 PM Thread Starter
Nitrosaki's Avatar
Hi guys
Anyone out there that might have a good suspension set up for drag racing? I have been told that the more hard the suspention is the better?
Nitrosaki is offline
post #2 of 8 Old 06-01-2014, 03:24 PM
zx racer's Avatar
Suspension setup plays big factor on rider weight, ridin style and wb. Give us lil more info so we can help.
05 ZX-10R SWB.
zx racer is offline
post #3 of 8 Old 06-01-2014, 05:13 PM
U need to set the bike up to u the thing people miss out in the most is the centerline if the bike (swingarm angle). A rear shock and cut forks are the big gains but must be fine to your wheelbase and weight of rider. Over looking a rear shock or using a busa shock is a bandaid get a shock dine
beanedisel is offline
post #4 of 8 Old 06-05-2014, 04:15 AM Thread Starter
Nitrosaki's Avatar
Okay guys so here goes:
I am about 80kg in weight and about 1.82m in length. Riding style - i come off the line with the clutch half out until i feel its good then let her rip. My bike is lowered in the back and the front. I have extension at the back. I am running both quickshifter as well as air shifter. The bike has a 55-80hp shot of dry shot nitros. My clutch is modded. The sprockets is 16/43. Powercommander as well as hub and handle bar switch for the extra fuel for the nos. I usually run a Mickey Thompson full slick(3221).
Hope i did not miss anything
SO?
post #5 of 8 Old 06-05-2014, 05:35 AM
BGoodwin22's Avatar
Best option is replace your rear shock with one designed for drag racing (JRI, Penske, Brocks, etc.). Second best option is to send your stock rear shock out for a revalve (to a shop who regularly sets up drag bike suspensions). In either case the goal is to have a shock with the comp and rebound characteristics needed to keep the chassis settled both during launch and down track. The shock will be set up for your specific weight and wheelbase.
BGoodwin22 is offline
post #6 of 8 Old 06-05-2014, 05:20 PM
TechX's Avatar
If your having traction issues soften the rear suspension to get more weight transfer to the rear. Experiment with rear tire pressures. If your not having any traction problems then just ride it.
TechX is offline
post #7 of 8 Old 09-06-2014, 10:49 PM
Who re-valves rear shock for drag racing
Briands is offline
post #8 of 8 Old 09-23-2014, 08:43 AM
flashf3's Avatar
Litz racing does stock shock revalves
Team TMP Performance
Flash's Speed & Customs, LLC
Certified Dynojet Tuning Center
flashf3 is offline
Gen 3: Rear Suspension Set-Up for Drag Racing BGoodwin22 Strip 7 10-11-2013 02:23 PM
Drag racing Clutch set-up 06green Strip 27 12-11-2006 07:21 PM
drag racing set-up hollywood99 Performance and Tech 1 08-31-2006 12:17 PM
Perfect Drag Set up????? bragg10r Race and Stunt 18 03-17-2006 08:42 AM
Drag Racing Suspension 1killer1liter Strip 9 05-27-2005 11:23 PM
