Nos Mini help - Kawasaki ZX-10R.net
post #1 of 15 Old 02-23-2013, 06:31 PM Thread Starter
Darmentle's Avatar
Nos Mini help
Hey anyone have any experience at hooking one of these up. I wanna make so its rpm activation but theirs so many wires coming off it and the direction are universal for anything. any help at all
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
Darmentle is offline
post #2 of 15 Old 02-23-2013, 06:44 PM
Slow Poke
bgmagma10's Avatar
I helped a buddy set one up on his. It's pretty straight forward man. The bigger wires are for the solenoid and ground. You won't need some of them unless you have an igniting module and your gonna retard timing. What are you needing to know?
bgmagma10 is offline
post #3 of 15 Old 02-23-2013, 06:50 PM Thread Starter
Darmentle's Avatar
so the red wire goes to the power side of the solenoid and the blue wire goes with the ground wire coming of the solenoid. do you know of any other wires coming off that i will need . Like tach signal?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #4 of 15 Old 02-23-2013, 08:39 PM Thread Starter
Darmentle's Avatar
Do you know what wires you used for the tps sensor and what wire for the coil pack. Like what color are the wires on the bike not the controller it self
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #5 of 15 Old 02-23-2013, 10:00 PM
gazx10's Avatar
from mini connect large black wire directly to neg. on battery. small black to good frame ground. large blue wire to one side of solenoid, mini large red wire to other side of solenoid.. green (tach signal) wire to # 1 coil uncommom colored wire. two wires to each coil, 4 same color, 4 different, tap uncommon color. three wires on tps, connect the white/blue stripe from mini to the center wire , it is the output for solenoid activation at certian throttle position. white from mini to your mini activation switch to arm system. this is all needed for one stage. yellow wire is for triggering other devices, rest are for 2nd solenoid activation.
gazx10 is offline
post #6 of 15 Old 02-23-2013, 10:07 PM Thread Starter
Darmentle's Avatar
OK the solenoid has two black wires and i have one of them grounded. So the blue and red wire coming off the mini go the other wire on the solenoid and then to battery?
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #7 of 15 Old 02-23-2013, 10:19 PM
gazx10's Avatar
large blk to neg. battery, small blk ground to frame. chgd my first reply, simplier just to wire solenoid with large blue and large red direct from mini. didnt mean to confuse.
gazx10 is offline
post #8 of 15 Old 02-23-2013, 10:22 PM Thread Starter
Darmentle's Avatar
Ok cool Thanks. I have MSD two step i wonder if i could run the tach green off the mini to one of the green tach wires off the two step. The two step plugs right into the coils on top to.
07 zx10
DDM Hid Kit 8k
K&N Air Filter
Velocity Turbo kit
Evil Swing Arm
Gen 3 Motor
PC3
post #9 of 15 Old 02-23-2013, 10:34 PM
gazx10's Avatar
i would tap the wires together as a single connection at the # 1coil wire, instead of placing the draw load for 2 step on the mini systems wire path, might intefere with the mini's signal.
gazx10 is offline
post #10 of 15 Old 02-23-2013, 10:48 PM
gazx10's Avatar
so you're going to run a wot 2 step in staging? if u do and wire the tps to activate the mini then u will hit the nitrous staged up throttle locked, clutch in if u reach the programmed nitrous start rpm while on the 2 step. at least u should, unsure how the mini is going to read that 2 step interrupted rpm signal.
gazx10 is offline
For Sale: NOS Mini 2 stage controller MWCMotorsports Parts, Gear and Accessories 8 02-02-2012 03:01 PM
For Sale: NOS Mini Nitrous Controller garth285 Parts, Gear and Accessories 1 12-16-2011 07:21 AM
Mini Nos Hookup wiring....tps, gear position and tach signal?? ke2012 Strip 1 08-14-2011 10:00 PM
nos mini 2 tank zx10r Wanted: Buy or Trade 2 02-02-2009 01:09 AM
nos mini tank zx10r Vendors deals 2 10-02-2008 08:59 AM
