Nitrous guys, show me your gearing - Kawasaki ZX-10R.net
post #1 of 45 Old 11-24-2009, 08:52 PM Thread Starter
I'm about to take the dive on a nitrous kit and spray bar and I wanted to see what everyone was running as far as front/rear sprockets go. My previous setup was -1,+3 with a 190 Shenko but I think I want to go more aggressive this time.
Bike will be primarily raced at the local 1/8th mile with the occasional trip to the 1/4 and will see some roll on street action against some high hp cars from time to time.
will -1,+6 be too much?
2006 Kawasaki ZX10R: Currently down for repairs after performing the "Rear End A Car Mod"
ExtendMy10R is offline
post #2 of 45 Old 11-24-2009, 11:10 PM
I think I'm gonna go -1 and +8 on my 08, which is 16/49. I'll have it out about 5" and be used for primarily my local 1/8th mile, but will be able to run 1/4. I may have to go to the stock front sprocket depending on how large a shot I eventually put on it.
Patrick is offline
post #3 of 45 Old 11-24-2009, 11:50 PM
wow yall are crazy!!!! you dont need that much gear guys..... depending on how much you weigh and what is done to your bike makes a big deal on the gearing not to mention how big of a shot your using !!!
*Extendmy10r your going to waste your money on a spray bar setup !!!! They dont work that great unless your using a wet system and to be honest we have made more power with single foggers then the spray bars have!!!!
The Blue 10 that runs out of are shop has a single fogger and it makes 180hp plus !!!! and yea its a street bike!!!!
J-N-M Motorsports home of the fastest ZX-10's
Da Flea is offline
post #4 of 45 Old 11-25-2009, 04:10 AM Thread Starter
Enlighten us then man! I'm here to hear other's experience. Here's my setup:
195 lb rider
06 10R
Roaring Toyz Slip on
BMC Race Filter
Stretched/Lowered (gonna call you about the swingarm)
Wet Nitrous kit with GSXR1300 spray bar (ordering this week actually)
PCIII
Butterflies removed.
I'm looking into a ported head and cams potentially but plan on keeping the stop bottom end and spraying a 40 shot. Gimme some input!
post #5 of 45 Old 11-25-2009, 06:58 AM
I'm 300lbs in boxers hence the gearing. Not to mention it will be a long time, if ever, before it sees nitrous.
I agree though, spray bars are junk.
Patrick is offline
post #6 of 45 Old 11-25-2009, 12:00 PM
195 lb rider
06 10R
BMC Race Filter
PCIII
sounds like your on the right path we will talk more when you call
Da Flea is offline
post #7 of 45 Old 11-25-2009, 12:01 PM
well if your going to run on motor then you would be fine with that gearing
Da Flea is offline
post #8 of 45 Old 11-29-2009, 07:03 PM
zx-sik-r's Avatar
i just pulled my motor so i dont mind telling my setup..here we go,keep in mind im 190 suited
11 over stock
penske double clicker
spyder nitrous=40 shot
stock motor
billet basket
air shifter
akra evo II ti
bmc filter
pump gas
pc III
bolt ons galore...u get my point
i run 2- 2+ for nitrous and was running in the 5.5x's in the 1/8 and my motor gear was 3- 4+ and was running in the 5.7x's and nobody could touch this bike in my area.like flea said the weight and setup are key..i could ride my boys 1000 and go a tenth faster just cause of weight.u need a good map also.i run the mini nos controller and it works flawlessly every fuckin time.going fast isnt cheap either if u wana run with the big boys u gota spend the $$$$$$$$$
zx-sik-r is offline
post #9 of 45 Old 11-29-2009, 07:11 PM
11 over stock
stock motor
billet basket
air shifter
akra evo II ti
bmc filter
pump gas
pc III
yea money makes speed !!!!!!
Da Flea is offline
post #10 of 45 Old 11-30-2009, 09:43 AM
Slow Poke
bgmagma10's Avatar
Yeah i would have really thought that -1 +6 would be way too much. I was -1 +2 for the motor. but when i put a 38 shot on it. i went back to just -1. and it seemed about just right. only went a [email protected] though. and i'm about 150 suited. had alot of clutch and tire problems.
bgmagma10 is offline
For you guys with Nitrous OneSLOW10 Performance and Tech 17 05-30-2008 10:54 AM
gearing??? mdihotmale The Out House 20 05-16-2008 10:38 AM
Nitrous and Turbo Guys.......... redline659 Performance and Tech 69 04-24-2008 05:16 PM
From all the guys down south to all you guys up north. 10 speed The Out House 11 12-08-2007 04:34 PM
gearing hollywood99 Strip 11 01-06-2007 10:27 PM
