Gen 1: 2004-2005 Newb to drag-racing - Kawasaki ZX-10R.net
post #1 of 37 Old 01-29-2013, 04:52 PM Thread Starter
zuhayr's Avatar
Newb to drag-racing
So I've decided to try my (clutch) hand at drag-racing
Had my first run on street setup on the 9th Dec 2012 and managed an 11.5 best time on the day (before my clutches started slipping:headshake)
Second day out I got into the tens (10.7) on my last run of the day (before my radiator mount broke off). I dropped the fork 20mm, had a custom fibreglass seat made up and set up the suspension for drags
Both days were run on Bridgestone BT016 tyres at road pressures.
I'm picking up a set of swingarm extentions but want to get into the 9's with the SWB. What do you guys think? Is it possible? Standard motor, exhaust and secondary butterflies removed, growler exhaust, PCIII, Dynojet dyno says 172 RWHP. I weigh 103 kg's naked (need to work on that ) so power to weight needs improving.
Any thoughts/comments/criticisms
Black/Green 2011 ZX10R
Black 2005 ZX10R, STOLEN
MRA double bubble screen, Fren Tubo braided hoses,
Ohlins steering damper, Brembo master cylinder,
Shogun frame sliders, BMC filter, Power Commander,
Growler end can, BT 016 sticky stuff, Pazzo shorties
zuhayr is offline
post #2 of 37 Old 01-29-2013, 09:14 PM
mrbzx7's Avatar
9's is possible swb, My bike is knocking on the 8's door on motor with very little engine work and stock exhaust. I'm only 145 lbs I still think you can do it, just lower it and change the sprockets to something more aggressive.
Andrews Motorsports
2009 ZX10R aka "The General"
2008 ZX14R coming soon!
Paypal [email protected]
mrbzx7 is offline
post #3 of 37 Old 01-29-2013, 09:45 PM
kuziken10r's Avatar
I ran a best of a [email protected] mph on my gen 1 mods were akra full exhaust pc3 bmc air filter down 2 front sprocket slammed and strapped with a 2ct tire and a fifth throttle....i KNOW with more seat time it would go faster oh and i weigh 145....seat time seat time seat time and you can do it.....the bike is more than capable....work on yourself slam it and strap the front and see what you can do
kuziken10r is offline
post #4 of 37 Old 01-30-2013, 07:52 AM
zx racer's Avatar
9's is very possible... im no fly weight 200# suited and i run low 6's in the 1/8 mid 9's in the 1/4 swb... best mods you can do is lower, strap the front end, regear the bike and get as much seat time as possible and you'll be in the 9's in no time.
05 ZX-10R SWB.
zx racer is offline
post #5 of 37 Old 01-30-2013, 08:20 AM
Slow Poke
bgmagma10's Avatar
Yeah man like said, your gonna have to get pretty greedy with gearing at your weight to get you movin but its definitely possible. Depending how comfortable you are with your clutch hand you can just get a 15 for the front. That'll give you a little more wheel base and plenty of gear to get you where you need to be. Plus its cheap and you can just take it right back off if you decide not to go the drag strip route. And make sure you run as much tire pressure as will hook. You really shouldn't need to drop your pressure much being swb. Good luck man!!
bgmagma10 is offline
post #6 of 37 Old 01-30-2013, 02:36 PM
Post Whore
-Op-'s Avatar
And I have no idea how this man does it lol. I weight about 200 in street clothes and go low 6 in the 1/8 stretched. Definently gear the bike and lower it with a strap. Thats your basic setup. Seat time seat time. Learning how to ride is the best thing you can possibly do.
-Op- is offline
post #7 of 37 Old 01-30-2013, 04:29 PM
zx racer's Avatar
good clutch hand and big set of ballz lol... but really man these bikes are well capitable of runnin some good times just gota set them up right my goal for this yr is to be in the 5's swb wish me luck.
05 ZX-10R SWB.
zx racer is offline
post #8 of 37 Old 01-30-2013, 06:40 PM
Post Whore
-Op-'s Avatar
haha goooood freakin luck man!! that will be an accomplishment for sure
-Op- is offline
post #9 of 37 Old 01-30-2013, 08:35 PM
zx racer's Avatar
thx man im not givin up till i reach my goal... hows your bike comin along did anything to it recently ?
05 ZX-10R SWB.
zx racer is offline
post #10 of 37 Old 01-30-2013, 09:54 PM
cookmaster30's Avatar
man its a horrible disease dont do it.
i dont even want to talk about my goal for this year
cookmaster30 is offline
Drag racing on a 1st gen Bigmarky Strip 11 05-09-2008 04:27 PM
04 Drag Racing GTStang330 Strip 7 07-05-2007 08:03 AM
drag racing set-up hollywood99 Performance and Tech 1 08-31-2006 12:17 PM
Me doing a little drag racing at Sac. 1killer1liter Strip 24 08-30-2006 06:55 PM
drag racing 04ZX10 Race and Stunt 19 06-10-2006 12:08 AM
